WD 2TB HDD disconnects every week
Algimantas
Hello,
I have 2TB WD External desktop HDD. The file system that i'm using is EXT2.
On this HDD i run transmission daemon and store media files.
The problem is that every week 7-8days it becomes red in the UI (Says that it wasn't cleanly unmounted) and remounts as sdb1. I ran e2fsck multiple times but it always says that it's clean. I even forced the check but nothing changed
System log show this kind of magic
Oct 27 15:22:45 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Oct 27 15:22:48 kernel: xhci_hcd 0000:00:0b.0: ERROR: unexpected command completion code 0x11.
Oct 27 15:22:49 kernel: usb 1-1: device not accepting address 2, error -22
Oct 27 15:22:49 kernel: xhci_hcd 0000:00:0b.0: ERROR: unexpected command completion code 0x11.
Oct 27 15:22:50 kernel: xhci_hcd 0000:00:0b.0: ERROR: unexpected command completion code 0x11.
Oct 27 15:22:50 kernel: usb 1-1: device not accepting address 2, error -22
Oct 27 15:22:50 kernel: usb 1-1: USB disconnect, address 2
Oct 27 15:22:50 kernel: sd 1:0:0:0: [sda] Unhandled error code
Oct 27 15:22:50 kernel: sd 1:0:0:0: [sda]  Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Oct 27 15:22:50 kernel: sd 1:0:0:0: [sda] CDB: Read(10): 28 00 27 80 18 10 00 00 08 00
Oct 27 15:22:50 kernel: end_request: I/O error, dev sda, sector 662706192
Oct 27 15:22:50 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #20709377: comm transmission-da: reading directory lblock 0
Oct 27 15:22:50 kernel: EXT4-fs (sda1): previous I/O error to superblock detected
Oct 27 15:22:50 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Oct 27 15:22:50 kernel: xhci_hcd 0000:00:0b.0: WARN: short transfer on control ep
Oct 27 15:22:50 kernel: force burst = 0.
Oct 27 15:22:50 kernel: xhci_hcd 0000:00:0b.0: WARN no SS endpoint bMaxBurst
Oct 27 15:22:50 kernel: scsi2 : usb-storage 1-1:1.0
Oct 27 15:22:50 rc_service: hotplug 6414:notify_rc restart_nasapps
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #83443713: comm hotplug: reading directory lblock 0
Oct 27 15:22:51 kernel: EXT4-fs (sda1): previous I/O error to superblock detected
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): __ext4_get_inode_loc:4908: inode #20709379: block 82837506: comm minidlna: unable to read itable block
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1) in ext4_reserve_inode_write:5747: IO failure
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): __ext4_get_inode_loc:4908: inode #20709379: block 82837506: comm bdi-default: unable to read itable block
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #20709378: comm minidlna: reading directory lblock 0
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): ext4_read_block_bitmap:349: comm minidlna: Cannot read block bitmap - block_group = 0, block_bitmap = 1025
Oct 27 15:22:51 kernel: EXT4-fs error (device sda1): ext4_discard_preallocations:3811: comm minidlna: Error reading block bitmap for 0
Oct 27 15:22:51 kernel: scsi 2:0:0:0: Direct-Access     WD       Elements 107C    1065 PQ: 0 ANSI: 6
Oct 27 15:22:51 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Oct 27 15:22:51 kernel: sd 2:0:0:0: [sdb] 3906963456 512-byte logical blocks: (2.00 TB/1.81 TiB)
Oct 27 15:22:51 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Oct 27 15:22:51 kernel: sd 2:0:0:0: [sdb] Write Protect is off
Oct 27 15:22:52 kernel: sd 2:0:0:0: [sdb] Assuming drive cache: write through
Oct 27 15:22:52 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Oct 27 15:22:52 iTunes: daemon is stopped
Oct 27 15:22:52 kernel:  sdb: sdb1
Oct 27 15:22:52 kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Oct 27 15:22:52 kernel: EXT4-fs (sda1): previous I/O error to superblock detected
Oct 27 15:22:52 hotplug[6415]: USB partition unmounted from /tmp/mnt/sda1 fail. (return -1, Device or resource busy)
Oct 27 15:22:52 kernel: EXT4-fs error (device sda1): __ext4_get_inode_loc:4908: inode #20709379: block 82837506: comm bdi-default: unable to read itable block
Oct 27 15:22:53 FTP Server: daemon is stopped
Oct 27 15:22:53 Samba Server: smb daemon is stopped
Oct 27 15:22:53 kernel: gro disabled
Oct 27 15:22:53 kernel: EXT4-fs (sda1): previous I/O error to superblock detected
Oct 27 15:22:53 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #83443713: comm sh: reading directory lblock 0
Oct 27 15:22:53 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #83443716: comm sh: reading directory lblock 0
Oct 27 15:22:53 Timemachine: daemon is stopped
Oct 27 15:22:53 rc_service: hotplug 6415:notify_rc stop_nasapps
Oct 27 15:22:53 rc_service: waiting "restart_nasapps" via  ...
Oct 27 15:23:23 rc_service: skip the event: stop_nasapps.
Oct 27 15:23:23 kernel: EXT4-fs (sda1): previous I/O error to superblock detected
Oct 27 15:23:23 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #83443716: comm sh: reading directory lblock 0
Oct 27 15:23:23 kernel: EXT4-fs error (device sda1): ext4_find_entry:921: inode #20709378: comm rm: reading directory lblock 0
Oct 27 15:23:24 syslog: USB partition unmounted from /tmp/mnt/sda1 fail. (return -1, Device or resource busy)
(20 more likes this log)
busy)
Oct 27 15:23:59 syslog: USB partition busy - will unmount ASAP from /tmp/mnt/sda1
Oct 27 15:23:59 rc_service: hotplug 6415:notify_rc restart_nasapps
Oct 27 15:23:59 iTunes: daemon is stopped
Oct 27 15:23:59 kernel: EXT4-fs (sdb1): warning: mounting unchecked fs, running e2fsck is recommended
Oct 27 15:23:59 hotplug[6452]: USB ext4 fs at /dev/sdb1 mounted on /tmp/mnt/sdb1
Oct 27 15:23:59 kernel: EXT4-fs (sdb1): mounted filesystem without journal. Opts: user_xattr
Oct 27 15:24:00 FTP Server: daemon is stopped
Oct 27 15:24:00 Samba Server: smb daemon is stopped
Oct 27 15:24:00 kernel: gro disabled
Oct 27 15:24:00 hotplug[6452]: USB partition unmounted from /tmp/mnt/sdb1
Oct 27 15:24:00 Timemachine: daemon is stopped
Oct 27 15:41:32 kernel: EXT4-fs (sdb1): warning: mounting unchecked fs, running e2fsck is recommended
Oct 27 15:41:32 hotplug[6452]: USB ext4 fs at /dev/sdb1 mounted on /tmp/mnt/sdb1
Oct 27 15:41:32 kernel: EXT4-fs (sdb1): mounted filesystem without journal. Opts: user_xattr
Oct 27 15:41:34 admin:  sh /opt/S95transmission.1 start
Oct 27 15:41:34 rc_service: hotplug 6452:notify_rc restart_nasapps
Oct 27 15:41:34 iTunes: daemon is stopped
Oct 27 15:41:34 FTP Server: daemon is stopped
Oct 27 15:41:34 Samba Server: smb daemon is stopped
Oct 27 15:41:34 kernel: gro disabled
Oct 27 15:41:34 Timemachine: daemon is stopped
Does anyone know what is going on and how can I solve it?
Try a different USB cable. If it still fails, try running a full surface scan of the disk to ensure it's not defective. I see a lot of read errors in that log.
Ok so I did the surface scan with Hdtune software. The disk is completely fine, no bad blocks detected. So I guess it has something to do with the router itself.
In my previous post I forgot to mention that i'm using johns fork as my router fw
Sent from my D6503 using Tapatalk
