MF-Bra
@RMerlin, is the https://www.asuswrt-merlin.net down ? getting 403 Forbidden (openresty/1.27.1.1) in the last few hours..
Thanks.
Thanks.
It appears to be up and working fine.@RMerlin, is the https://www.asuswrt-merlin.net down ? getting 403 Forbidden (openresty/1.27.1.1) in the last few hours..
Thanks.
My provider seems to be doing server updates and breaking stuff along the way. A few days ago they made a change that removed the PHP handler I was using, I had to switch to a different PHP handler.@RMerlin, is the https://www.asuswrt-merlin.net down ? getting 403 Forbidden (openresty/1.27.1.1) in the last few hours..
Thanks.
Interesting, still offline for me. Shift refresh and trying from mobile without any previous access to the page (no cache at all) shows the same. Any chance a regional/ip restriction being applied ?It appears to be up and working fine.
It's working here in the UK, as it was yesterday. However, if I switch to Brazil using a VPN I see the same error as you. Other South American countries seem to be OK.Interesting, still offline for me. Shift refresh and trying from mobile without any previous access to the page (no cache at all) shows the same. Any chance a regional/ip restriction being applied ?
Thanks, after seeing previous messages I did the same VPN test and it worked. Thanks for your confirmation!It's working here in the UK, as it was yesterday. However, if I switch to Brazil using a VPN I see the same error as you. Other South American countries seem to be OK.
Completely agree there is no reason for such a thing, and that's why I didn't test with a VPN prior to reporting here, but it's confirmed there are some restrictions applied.Can't imagine any reason for regional restriction(s) for such a site.RMerlin does acknowledge an intermittent issue here: https://www.snbforums.com/threads/asuswrt-merlin-3006-102-7-is-now-available.96796/post-986545
I use Cloudflare. They might be experiencing issues within your region. I don't have any regional block in place.Completely agree there is no reason for such a thing, and that's why I didn't test with a VPN prior to reporting here, but it's confirmed there are some restrictions applied.
Just to take a look at if you use WAF in CF maybe some lazy configuration that bothers some countries. m2cSeems to be country-specific then.
I opened a ticket with the hosting provider, having already confirmed on my end that the issue isn't caused by Cloudflare.
I completely disabled proxying to confirm that CF wasn't the issue.Just to take a look at if you use WAF in CF maybe some lazy configuration that bothers some countries. m2c
We use essential cookies to make this site work, and optional cookies to enhance your experience.
