Skynet WebUI Support on XT8 (388.1_0-gnuton1)
mattmcspirit
Hey @Adamm,
After a fresh factory-reset-then-install-then-reset of 388.1_0-gnuton1 on my XT8 AiMesh nodes, I've installed Skynet v7.3.6, and the core functionality appears to be running fine (after waiting a few mins for locked files etc) - apart from during install, or later through settings, it seems that the WebUI components aren't getting installed correctly.
The Skynet tab appears in the WebUI, but errors out to a 404 - enabling the WebUI from Settings shows:
/jffs/scripts/firewall: line 5631: can't open /tmp/mnt/USB/skynet/webui/skynet.asp: no such file
[i] Mounting Skynet Web Page As user2.asp
cp: can't stat '/tmp/mnt/USB/skynet/webui/skynet.asp': No such file or directory
[i] WebUI Enabled
[i] Generating Stats
During the main install (or reinstall), other errors include:
[*] Updating chart.js Failed
[*] Updating chartjs-plugin-zoom.js Failed
[*] Updating hammerjs.js Failed
[*] Updating skynet.asp Failed
Followed steps here: https://www.snbforums.com/threads/no-web-access.70600/post-668732 to manually pull down the files:
skynetloc="$(grep -ow "skynetloc=.* # Skynet" /jffs/scripts/firewall-start 2>/dev/null | grep -vE "^#" | awk '{print $1}' | cut -c 11-)"
curl -fL https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/master/webui/chart.js -o "${skynetloc}/webui/chart.js"
curl -fL https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/master/webui/chartjs-plugin-zoom.js -o "${skynetloc}/webui/chartjs-plugin-zoom.js"
curl -fL https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/master/webui/hammerjs.js -o "${skynetloc}/webui/hammerjs.js"
curl -fL https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/master/webui/skynet.asp -o "${skynetloc}/webui/skynet.asp"
and restarted firewall - this fixed the issue and after restarting Skynet, Skynet in WebUI displayed correctly.
Re-testing again, by updating (with force), gave similar install issues:
[i] Forcing Update
[i] New Version Detected - Updating To  (d41d8cd98f00b204e9800998ecf8427e)
[i] Saving Changes
[i] Unloading Skynet Components
[*] Updating firewall.sh Failed
[i] Restarting Firewall Service
Done.
Debug info shows all green, and I guess because I manually downloaded the WebUI files, it's able to successfully show them.
Could something be blocking pulling down the WebUI files during install/update?
Thanks!
Matt
