WebUI unresponsive
Pugger
Greetings!
I been lurking the forums a good amount of time to look for the solution I am running into but no luck. My WebUI for my AC5300 becomes unresponsive after 10mins or so after the router is started up or rebooted.
I have attempted many different solutions from imaging the stock firmware, different firmwares of Merlins, even tried DD-WRT and same result. Besides the WebUI, everything is working great. SSH does not show any red flags that I can see and network services as for speed and connections no issues.
It seems just to be the WebUI I can not be able to keep up. I am running stock Merlin with no addons or changes to configuration but I am out of ideas.
Any suggestions would be awesome! Thanks!
Greetings!
Have you tried restarting httpd:
service restart_httpd
I have tried restarting the service but it locks back up after 10mins. Is there a log of the httpd that I could check or I have to enable debugging for it?
Same thing here. I run the command and finally get the login prompt but it still does not load the index.asp page.
