What am I doing if I block Google public DNS?
Not exactly... we're losing money on bird seed!
Yes, you have to make investments in order to attract... birds. :)
What happened to the Ubiquiti product detail in your signature...
I have 4x networks already, some changes here and there, but in general the same GbE setups with UCG-Ultra gateways, universal omnidirectional U6-Mesh access points and whatever needed switches USW-Ultra and USW-Flex-Mini. Fair price hardware, power efficient and trouble free. Site Magic is site-to-site WireGuard based VPN, Teleport is Tailscale WireGuard based VPN for mobile devices outside of LAN.
I have to make investments to keep the bird I married! We're at 43 years and counting.
Thanks for the product detail. I've got some reading to do.
OE
I'll give you real life numbers. The UCG-Ultra ($129) is GbE capable 3-in-1 Gateway, Controller and Switch. Very small device and only 6W. It can go Gigabit WAN-LAN with IDS (Suricata), ~500Mbps with QoS (FQ-CoDeL or Application), ~500Mbps on WireGuard and ~150Mbps on OpenVPN. U6-Mesh ($179) is Gigabit capable AP with IPX5 rating for indoor/outdoor applications, very small size device and only 13W, omnidirectional radiation pattern, PoE injector is included, desktop stand and wall/pole mounts are included. With UCG-Ultra you can expand your network up to 30 UniFi devices and up to ~300 clients. Wired performance is 940Mbps, wireless performance on 80MHz wide channel is ~800Mbps to common 2-stream AX-class client. U6-Mesh range at 30dBm EIRP is similar to RT-AX86U AIO router in my environment.
fax 802.1Q (VLAN) under WAN and LAN-IPTV under LAN, doing the same job?? ASUS Wi-Fi 1
