What Temps are your Radios/processors running?
Raiu
Here are mine:
Legend: 2.4 GHz - 5 GHz - CPU
Current Temperatures: 127 °F - 133 °F - 181 °F
Running 68u Merlin 40 alpha 4 with overclock enabled and 16 clients
Is there a toggle to display the temps in Fahrenheit? Mine are in Celsius.
@ Raiu, I see you added to your post that you have over clocked that may explain why your temps are higher. Can you tell me because I have no idea what over clocking your CPU does for performance is there a big improvement ??
That's what I was thinking tbh. It seems that its able to handle the work load a lot better. Meaning my wife can stream her classes on her laptop. I can stream netflix on the Apple TV and browse the internet up stairs on my ipad with less lag like I was getting with stock firmware. Maybe it's placebo?
Ok thanks for explaining that. I don't seem to see any lag doing multiple streams and internet surfing with the stock CPU speeds. But my connection is fast my internet speeds are about 115 to 122 down and 23 up.
My ISP caps me at 25 down can't afford the 50its like 120 a month. Wish we had access to types of speeds though I'm sure they would be charging 200$ for it damn cox cable
Hey I hear you, I have Comcast here and I would not pay for the high speeds I am getting right now but they just recently doubled there speeds for no extra cost in my area. I use to just have there Blast 50/10.
Thanks for the heads up regarding Comcast doubling their speed. I have Comcast and just did a speed test and I'm pulling 116 mbit/s down. They didn't even announce the speed increase, I had no idea.
After doing a cheap $3 fan mod I have seen temps drop at-least 30 Degrees Celsius from the CPU. This is one of the hotter speeds it runs at and can even go 5 Degrees lower on a cooler day :cool: I'll take pictures for others later to see but I highly suggest buying cheap computer fans off eBay and splicing the cables to and old USB cord (red wire to red, black to black) then using velcro sticky dots to attach it to the router. :D (also using a cheap powered USB hub so I can run up to 10 devices separate from the routers USB ports)
Current Temperatures: 111 °F - 115 °F - 140 °F
Current Temperatures: 44 °C - 46 °C - 60 °C
