What's wrong with my RT-AC56U?
yelo3
I'm trying to understand why my RT-AC56U has a weak 2.4 GHz wifi (lots of disconnections) and low transfer speed if I'm not very near to it.
Can you please post the result of these commands, even if you don't have an AC56U?
I think there is something wrong with my configuration
wl country
wl txpwr_target_max
wl chanspec_txpwr_max
wl txpwr1
wl pwr_percent
Thank you for your help
Hi, I am using a RT-AC56U running 380.65_4 bought in Denmark and here is my results:
wl country
DE (EU/13) GERMANY
wl txpwr_target_max
Maximum Tx Power Target (chanspec:0x180b): 14.00 14.00
1       (0x1001)        15.50(dbm)
2       (0x1002)        15.50(dbm)
3       (0x1003)        15.50(dbm)
4       (0x1004)        15.50(dbm)
5       (0x1005)        15.50(dbm)
6       (0x1006)        15.50(dbm)
7       (0x1007)        15.50(dbm)
8       (0x1008)        15.50(dbm)
9       (0x1009)        15.50(dbm)
10      (0x100a)        15.50(dbm)
11      (0x100b)        15.50(dbm)
12      (0x100c)        15.50(dbm)
13      (0x100d)        15.50(dbm)
5u      (0x1903)        15.50(dbm)
6u      (0x1904)        15.50(dbm)
7u      (0x1905)        15.50(dbm)
8u      (0x1906)        15.50(dbm)
9u      (0x1907)        15.50(dbm)
10u     (0x1908)        15.50(dbm)
11u     (0x1909)        15.50(dbm)
12u     (0x190a)        15.50(dbm)
13u     (0x190b)        15.50(dbm)
1l      (0x1803)        15.50(dbm)
2l      (0x1804)        15.50(dbm)
3l      (0x1805)        15.50(dbm)
4l      (0x1806)        15.50(dbm)
5l      (0x1807)        15.50(dbm)
6l      (0x1808)        15.50(dbm)
7l      (0x1809)        15.50(dbm)
8l      (0x180a)        15.50(dbm)
9l      (0x180b)        15.50(dbm)
wl txpwr1
TxPower is 127 qdbm, 31.75 dbm, 1496 mW Override is Off
wl pwr_percent
100
Also consider interference which can cause the issues you reported. Doesn't matter what power you run on your WiFi...if the airwaves are already saturated, your performance will be in the crapper.
Actually it's not saturated.
To do some tests I've also placed an old router next to my asus and the old one performs better
T Solved what I am doing wrong (DDNS) Asuswrt-Merlin 2
C What is wrong with DDNS.. Asuswrt-Merlin 14
D Rules wrong Asuswrt-Merlin 11
