Where are the IPS stored for created IPsets with x3mRouting.sh
ComputerSteve
I want to see the list of IPS created with this command
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 ALTICE asnum=AS6128 # Route-Altice-One traffic via Wan
Where are those lists stored ?
I see the Amazon_global when I created that using this command in x3mRouting ipset_name=AMAZON_GLOBAL aws_region=GLOBAL but I don't see any others.. Meaning I don't see a file called ALTICE with all IPS inside it. How can I get this list of IPS?
Run:
ipset list
Thanks.. See I'm having a problem every time I reboot the router it doesn't auto populate the list of IPS.. Meaning I have to manually open up terminal and run this command sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 ALTICE asnum=AS6128 # Route-Altice-One traffic via Wan.. Then it shows a populated IPSET if I don't do that when I run liststats I see ALTICE 0 ... Is there any suggestion on maybe fixing that?
J Skynet Skynet - Removing old ips from a previous import Asuswrt-Merlin AddOns 5
