Solved Which firmware image for the RT-AX3000 V2?
armv8
I have an RT-AX3000 V2. The non-TUF variant. Here is the product page.
# nvram show | grep -E 'AX58|AX3000|TUF'
size: 73307 bytes (123301 left)
build_name=RT-AX58U_V2
lan_hostname=AX3000
lld2d_hostname=RT-AX3000
model=RT-AX58U_V2
odmpid=RT-AX3000
productid=RT-AX58U_V2
webs_state_odm=RT-AX58U_V2
wps_device_name=RT-AX3000
wps_modelnum=RT-AX3000
asus_device_list=<3>RT-AX3000> [...]
cfg_device_list=<RT-AX3000>10> [...]
I'm not sure if I should use the firmware for the TUF-AX3000 V2 or the RT-AX58U V2. My router looks exactly like the latter, but the former has the closer model name.
It looks like Gnuton may have made a port for that model.
Yeah, I am talking about the gnuton (ng) firmware images. The issue is that there isn't a file specifically for the RT-AX3000 V2. Just the TUF-AX3000 V2 and the RT-AX58U V2.
As far as I can tell, they are all very similar. I have a feeling that one or both of them will work, but I'd like to know for sure before I try it.
