Nope, as it's simply not needed: Go to your VPN provider and ask for the Router or Andorid .ovpn config file and load it to the router - add Login/PW and you are done!![]()
I believe Astrill's applet uses Router VPN Pro Stealth and does some type of additional security routing. Direct OpenVPN does not yield those speed results in all my tests.
