Hello, I have an Asus AXE11000 router and only one ax client, my PC. When I run wifi insight from the router, I see that my max PHY rate is 54 and I don't know if that is normal or not? The Max PHY rate for 5G is 1733 and for 2.4 it is 385. It seems odd that the 6E band would be so low, or maybe not, what do I know.
To confuse things further, the router reports the 6E Tx (Mbps) rate is anywhere from 1300 to 1900 while Rx is 800 to 1100 Mbps. The SNR is 93.
I suspect the WiFi Insight from the router is buggy for 6E?
I'm the only 6E client in my neighborhood, just one.
Any insights would be helpful.
