WiFi Drops w/No Indications - Drunk Sister & Hot Router w/Logs
BJ1200
Do the partial logs below look like the AC66U router is disconnecting frequently? It says "entering disabled state" many times. I can't determine if the issue is router or WiFi cards.
A week ago my sister "supposedly" lost internet connection at 2AM and drunk. She "unplugged cables" to reset the modem but also shoved the router into a crevice behind the cabinet About 3 days after she did this the connection issues started. I then found the mess and the router was fire hot.
The 5Ghz drops about every 5-10 minutes, especially on the one laptop. After a few minutes it would sometimes reconnect . But the taskbar WiFi icon always shows all is OK. When this laptop would stop connecting I would test the other PC browser. It would connect to websites. I switched to 2.4Ghz and the drops still happen.
Jun 4 01:08:07 rc_service: httpd 349:notify_rc restart_wireless
Jun 4 01:08:07 kernel: br0: port 2(eth1) entering disabled state
Jun 4 01:08:07 kernel: device eth1 left promiscuous mode
Jun 4 01:08:07 kernel: br0: port 3(eth2) entering disabled state
Jun 4 01:08:07 kernel: device eth2 left promiscuous mode
Jun 4 01:08:11 kernel: device eth1 entered promiscuous mode
Jun 4 01:08:11 kernel: br0: port 2(eth1) entering listening state
Jun 4 01:08:11 kernel: br0: port 2(eth1) entering learning state
Jun 4 01:08:11 kernel: br0: topology change detected, propagating
Jun 4 01:08:11 kernel: br0: port 2(eth1) entering forwarding state
Jun 4 01:08:11 kernel: device eth2 entered promiscuous mode
Jun 4 01:08:11 kernel: br0: port 3(eth2) entering listening state
Jun 4 01:08:11 kernel: br0: port 3(eth2) entering learning state
Jun 4 01:08:11 kernel: br0: port 3(eth2) entering forwarding state
Jun 4 01:22:16 miniupnpd[996]: upnp_event_recv: recv(): Connection reset by peer
Jun 4 03:25:29 rc_service: httpd 349:notify_rc restart_wireless
Jun 4 03:25:29 kernel: br0: port 2(eth1) entering disabled state
Jun 4 03:25:29 kernel: device eth1 left promiscuous mode
Jun 4 03:25:29 kernel: br0: port 3(eth2) entering disabled state
Jun 4 03:25:29 kernel: device eth2 left promiscuous mode
Jun 4 03:25:33 kernel: device eth1 entered promiscuous mode
Jun 4 03:25:33 kernel: br0: port 2(eth1) entering listening state
Jun 4 03:25:33 kernel: br0: port 2(eth1) entering learning state
Jun 4 03:25:33 kernel: br0: topology change detected, propagating
Jun 4 03:25:33 kernel: br0: port 2(eth1) entering forwarding state
Jun 4 03:25:33 kernel: device eth2 entered promiscuous mode
Jun 4 03:25:33 kernel: br0: port 3(eth2) entering listening state
Jun 4 03:25:33 kernel: br0: port 3(eth2) entering learning state
Jun 4 03:25:33 kernel: br0: port 3(eth2) entering forwarding state
