WiFi guest subnet and scripts
DarkSNet
Hi everyone, I’m new here and thank you.
I have an Asus ROG GT-AX6000 running Merlin 3006.102.5.
My main network is on IP address 192.168.2.1. I’ve created a separate network for IoT using the “Guest Network Pro” section, on the 192.168.54.1 subnet.
I’d like to route traffic from the IoT network to reach my scripts that are already running on the main network, while keeping the IoT subnet isolated. I’ve tried everything I could think of, but I can’t get it to work.
Is there a way to do this?
Thanks a lot.
Then check the respective scripts support threads and the compatibility and configuration specifics in 3006 firmware.
If you have not done so already, use the search feature to find the past discussions on trying to get Guest Network Pro clients to access the main LAN clients when using 3006 firmware. There are a number of discussions with varying degrees of success. Some past discussion links:
Example scripting using a /jffs/scripts/firewall-start file:
https://www.snbforums.com/threads/t...st-network-pro-limitations.94438/#post-952345
Bottom line, some are finding that when they set the Guest Network Pro option Use same subnet as main network to disable/off that the Guest Network Pro option Access Intranet doesn't work properly. Some are resorting to using a firewall-start script to allow traffic to flow between Guest Network Pro clients and the main LAN clients. If one is trying to get Guest Network Pro clients to use a DNS server located on the main LAN, they can use DNS Director's Guest Network Pro profiles to set local network DNS resolvers for one's Guest Network Pro Profiles.
And as already indicated, check the Addon subforum for the specific addon script discussions to see if there are special settings needed for Guest Network Pro clients on 3006 firmware, and to ask questions to the developers of those scripts. Example:
