Wireless access points -connectivity
Amadeus1756
I have a very wide house which means I don't get much in the way of wifi at one nd of the hose and in the garden.
I'm looking to replace my current router (netgear wndr3700) with something else - possibly a couple of asus models. Looking in the manual for these it says that you need to use wep when making one an AP. is this normal? It doesn't seem very secure.
clarifying... when using a WiFi repeater also called WDS or range extender... yes, often you must use WEP. But WDS/repeaters are last resort in improving coverage.
Better: Get a WiFi access point (AP) or re-purpose a spare WiFi reouter to be an AP. There's a FAQ here on the forum on how to do that. Place it near the weak signal area. Connect it to your router by:
a) cat5 cable (if feasible to run in attic, under house, etc.
b) buy a pair of HomePlug devices ($80 or so) and use them to replace the cat5 cable you cannot run. They move the connection via the AC power wiring.
c) If there is existing TV coax near the router and somewhat near where you might place the AP, you can use a pair of MoCA devices instead of (b). Better choice since it's not vulnerable to noise on the AC power line. There's a MoCA and HomePlug section on this forum.
A high transmitter power WiFi router won't cure the problem of weak signal going TO the router.
Thanks Steve. Sorry for the delay in posting - I hadn't seen that there had been a reply.
I may well run a cable from my current router to the new one - that would be ideal. I don't really want to go down the powerline or wireless connection route if possible as I was thinking I'd put my (future) NAS away from the wired PCs so I want to keep as much speed as possible.
I was just surprised that connecting an AP to a router required WEP - a widely derided solution to any problem. It's not a concern to me as if I can't access my network from one side of the house, other people won't be able to from much further away! :-)
If you can't run Ethernet, powerline is generally going to provide higher and more reliable throughput than wireless.
If you are going to put a NAS on a wireless connection, don't bother buying a high-performance NAS.
Airport 802.11n extended networks support WPA2 just fine :D
If possible, run Ethernet to the other AP
Again, depends on the WAF (Wife Approval Factor) - homeplug and MoCA are decent alternatives to stringing a CAT5/6 discretely...
more power is not better, absolutely agree there...
