Wireless light not on for linksys WRT350N
vietkool
I have a linksys router WRT350N . it's a workhorse I've been using it a love it but recently got problem with wireless, the LED not light up anymore so there is no way for me to use wireless in house. but all the wired port are working fine as usual. is anyone know what happened ? a how to fix it.
I did the firmware upgrade then hard reset but no luck. also called tech support but they didn't know what happened. The tech support guy tried to sell me a new router E2000 he said it the most advantage one out there now for Home user router.
pls help !!!!
pls help !!!!
E2000 replace the WRT3xx series. Though the light gone out? Did the wireless go out also?
YEAH , the green LED went out then my wireless stop working I try 4 laptop and the iphone, none of them have the name of the router wireless appear on the network list
Well it's 3 years old the wireless died. Wired works. So you can just buy wireless access or a router with access point features. You see the list here on SNB. Buffalo wireless is strong, but if you want to stick with C/L then pickup E2000 you can disable the NAT/SPI/DHCP give a static IP, subnet mask and default gateway your router. Us that. There are some older WRT310, 320 around for $89 bucks brand new in the box at Samsclub if you live USA.
B Intermittent wired/wireless connection General Wi-Fi Discussion 50
