Wireless log is empty
Hansemanne
The page Main_WStatus_Content.asp never gives me any clients.
I have cleared browsers and reset the router.
Open your web browser console and look for any error message.
Also, please provide router model and firmware version used.
Thank you for swift reply.
Router model is Asus RT-Ac5300 and firmware version is 384.6.
I do get errors:
Uncaught SyntaxError: Unexpected token ;
Main_WStatus_Content.asp:161 Uncaught ReferenceError: initial is not defined
at onload (Main_WStatus_Content.asp:161)
onload @ Main_WStatus_Content.asp:161
I do get errors:
What's on the line with the "Uncaught SyntaxError: Unexpected token ;" error?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<html xmlns:v>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta HTTP-EQUIV="Pragma" CONTENT="no-cache">
<meta HTTP-EQUIV="Expires" CONTENT="-1">
<link rel="shortcut icon" href="images/favicon.png">
<link rel="icon" href="images/favicon.png">
<title>ASUS Wireless Router RT-AC5300 - Wireless Log</title>
<link rel="stylesheet" type="text/css" href="index_style.css">
<link rel="stylesheet" type="text/css" href="form_style.css">
<script language="JavaScript" type="text/javascript" src="/state.js"></script>
<script language="JavaScript" type="text/javascript" src="/general.js"></script>
<script language="JavaScript" type="text/javascript" src="/popup.js"></script>
<script language="JavaScript" type="text/javascript" src="/help.js"></script>
<script language="JavaScript" type="text/javascript" src="/js/jquery.js"></script>
<script language="JavaScript" type="text/javascript" src="/client_function.js"></script>
<style>
.wifiheader{
background-color:#475a5f;
color:#FFCC00;
p{
font-weight: bolder;
</style>
<script>
overlib_str_tmp = "";
overlib.isOut = true;
var refreshRate = 3;
var timedEvent = 0;
dataarray24 = ["Bifrost","0","0","-92","2","2C:4D:54:09:8D:00","AP"];
wificlients24 = [["88:83:22:B5:05:E6","192.168.1.164","Galaxy-J5-2016","","-56","6", "1"," 1:30:29","PST_AU_"],["20:F8:5E:AD:A3:62","192.168.1.234","SmartPlugada362","","-66","11", "11"," 10:50:34","P___AU_"],["20:F8:5E:AE:4B:EE","192.168.1.153","SmartPlugae4bee","","-67","11", "11"," 10:50:34","P___AU_"],["00:09:B0:91:B1:04","192.168.1.38", "*","","-68","39", "1"," 10:51:08","_ST_AU_"],["00:04:20:2B:1D:EC","192.168.1.252", "SqueezeboxRadio","","-50","54", "54"," 10:51:22","____AU_"],["00:9C:02:25:AF:44","192.168.1.120", "HP25AF44","","-51","65", "65"," 10:51:26","____AU_"],"-1"];
dataarray5 = ["Bifrost","0","0","-91","136","2C:4D:54:09:8D:08","AP"];
wificlients5 = [["40:40:A7:9C:35:E8","192.168.1.160","android-714ac399b5d19706","","-59","24", "86"," 1:11:39","PS__AU_"],["EC:1F:72:A7:96:BA","192.168.1.14","android-f81a0264c84c44bc","","-63","24", "173"," 1:30:04","PS__AU_"],["C0:EE:FB:D5:1F:8F","192.168.1.151","OnePlus_3","","-80","6", "26"," 1:59:56","PSTMAU_"],["F8:77:B8:95:BA:50","<not found>","<not found>","","-67","24", "173"," 5:00:32","PST_AU_"],["54:60:09:7E:72:AC","192.168.1.215","Chromecast","","-74","65", "57"," 7:29:42","_S__AU_"],["54:60:09:12:03:92","192.168.1.203","*","","-64","86", "65"," 8:46:20","_S__AU_"],"-1"];
dataarray52 = ["Not associated. Last with <unknown>","","","","","","AP"];
wificlients52 = [
; <------- THIS IS MARKED AS AN ERROR!!
function initial(){
show_menu();
refreshRate = getRefresh();
get_wlclient_list();
if (bcm_mumimo_support) {
document.getElementById("flags_mumimo_div").style.display = "";
document.getElementById("flags_div").style.display = "none";
... MORE CODE..
wificlients52 = [
The problem is related to your second 5 GHz radio. Did you disable it? Are you using Smart Connect, or manually configuring all three bands?
I use Smart Connect. I can see that with default settings I never ever have any clients connected on the 2nd 5 GHz band.
Anyhow, should not the coding of the ASP-page have a fault handling? And secondly, isn't ASP a bit old fashion?
Thank you for your efforts!
The Javascript is dynamically generated by the web server. If something is bugged in the code generation, it will generate broken Javascript that will prevent the browser from parsing it. You can't "prevent bugs" from happening...
This is not Microsoft ASP. This is plain Javascript + HTML, with large portions of the code generated dynamically by the web server.
