Wireless MAC Filter
keef
Hello.
I am using Merlin 384.4_2 on an Asus RT-AC87R. I am trying to use the wireless MAC filter to occasionally lock out a device. I am able to lock out, then re-enable the device successfully. What I cannot understand is if Iook at the entry how I I know if it is set to access or reject status?
Using Network Map if I click the globe for the device (allow internet access) it does not seem to do anything.
Under Client Status I select block the device still has a access.
Is there another way to kill a device's access from time to time?
thanks, Bj
Have you looked at time scheduling under Parental Controls, which is a sub-section of AIProtection?
Would that serve your needs?
Thanks a lot. That just might do it. I forgot about all the AiProtection stuff. Some of that might be awkward to use since I have Skynet and Astrill VPN but what the heck, I'll give it a try when no one is home.
thanks, Bj
thanks, Bj
FYI: I notice that there is an "Enable wireless scheduler" option under the Wireless/Professional tab. Might this be a better option than turning on parental controls?
I completely missed that smart feature! That would work provided keef doesn’t want to connect other devices wirelessly during the periods when he wants to exclude the device in question.
I think you're right. Probably needs to be selective, not the entire group.
