Wireless-N Bridge for WPA2 Enterprise network
pradeepsekar
I have a Wireless-N network with WPA2-Enterprise security. I am looking for a bridge (or a router that can act as a bridge) for the network - I have some wired devices that I need to connect to the network.
The problem is that I am unable to find any wireless bridge that is capable of connecting to a WPA2-Enterprise network. All the bridges (and routers in bridge mode) I have seen only support WPA2-Personal and that does not work for my network...
Has anyone been successful in using a wireless-N bridge capable of connecting to a WPA2-Enterprise network?
Thanks,
Pradeep
I don't know of any products offhand. You might have better luck with a bridge supporting client mode vs. WDS. Or an AP that also supports client mode.
Check EnGenius. They make a lot of different APs.
Wireless-AC Bridge for WPA2 Enterprise Network
I have found this Silex BR-310AC but it's hard to find. Do you guys have found other bridges which support Enterprise security?
High Performance Gigabit Ethernet to 802.11ac WLAN Bridge Including 802.1X Enterprise Security
BR-310AC is a high-performance wireless network adapter which enables any Ethernet device to become an 802.11a/b/g/n/ac dual band wireless network device, giving the freedom to place it anywhere in your facility.
https://www.silextechnology.com/connectivity-solutions/device-connectivity/br-310ac
