InvisibleRasta
Hello guys i need a wifi repeater. I currently have a netgear ex3700 but i am having issues with it... alot of disconnects and really slow. I have it hanging outside my shed window in a plastic bag for the rain and this way i can get my wifi at 18% strenght.
i been searching a bit in google but i see that some range extenders need to be plugged into the router but this will not work for me as the router is too far and cant use a cable. I am looking for a repeater that will connect to my wifi network and repeat it into a new network.
i have found this outdoor extender:
TP-LINK CPE210 or TP-LINK CPE510
But from what i understand this two need to be attached to a router in my house to give it power trought an ethernet cable. Am i correct?
So basically i would habe to use a router like a TP-Link TL-WR941ND
Other option i found is this: wavlink ac600 but i am not sure if it needs a router or how it works
Whats the best solution? I need a strong antenna to get connected to my main wifi but then not a very strong wifi in the shed as it is really tiny.
Thank you
Thank you
