Joppez
I am running my LAN with an RT-AC68U with 384.4_2, which has never failed me before.
This started today (without any firmware upgrade or change of settings), I can no longer browse https://www.quora.com or https://eu.battle.net/login/ (and many other sites), but most sites works just as normal.
If I click the main button in Network Protection/AiProtection (the one marked Enabled AiProtection) to turn it off, everything works again. If I don't do that the sites just hangs with "Negotiating TLS Connection" in my browser.
However, since I suspected that this was connected to "Malicious Sites Blocking", I have tried to turn that off and also the two others (Two-Way IPS and Infected Device Prevention and Blocking), but turning them off one by one or even all three of them at the same time, does not help. The only thing that helps is completely disabling AiProtection, which I don't want to do.
Any ideas what the problem might be?
