Hello!
So I have everything up and running finally on my old WL-500gP router.
However, I have a problem I get slow speeds with Transmission up to 800KB/s, normally I can get up to 1.5MB/s with the same good seeded torrents from my PC and Transmission also reports that the port is closed.
I'm going to attach the settings of what I have done so far.
Thanks in advance.
Please note:
In uTorrent I have UPnP and NAT-PMP port mapping enabled.
uTorrent also reports that the port is closed.
Also in Transmission UPnP doesn't work, it still reports that the port is closed.
Thanks in advance.
Please note:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 4,
"dht-enabled": true,
"download-dir": "/tmp/harddisk/transmission/download",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 2,
"idle-seeding-limit": 1,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/usr/local/root/Downloads",
"incomplete-dir-enabled": false,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"message-level": 2,
"open-file-limit": 64,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 500,
"peer-limit-per-torrent": 100,
"peer-port": 50126,
"peer-port-random-enabled": false,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 1,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 0.0098,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{6f7242c584183be3b79cf89bea7741f9c7f6c904gZwnn/Qb",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "",
"rpc-whitelist": "127.0.0.1,192.168.0.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 500,
"speed-limit-down-enabled": false,
"speed-limit-up": 20,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 14,
"utp-enabled": true
