Hej,
I have been playng with 3 different adapters and WNDR3700 WIFI the last days.
Adapters are:
Edimax EW-7811UN Wi-Fi 150Mbps Mini USB
TRENDnet TEW-649UB 300Mbps
AR5B93 (Acer 5738ZG laptop and last driver for Atheros)
The results are "depressing"!!
With all 3 adapters:
Using 130 mbps (default), good signal, no surfing! meaning that access to internet should be OK according to Win 7, but browsing no pages, cannot connect to router, but can ping it.
Using 300mbps same issue...
Using 54mbps, very good connection and speed with AR5B93.. all work fine, 3 out of 5 bars signal. 20-22mbit both ways (I have fibre 30/30)
With the 2 other adapters, I can surf, signal is 5 out of 5 (excellent) speed is a disaster, testing with speedtest.net.
I have 30/30 mibt fibre, with the laptop's card I reach 26 mbit up/down, with the 2 other adapters, even if 5/5 in signal 3 mbit down and up.
I have no idea why I cannot connect at all with 130/300 mbps even though the adapters are N compatible. The 2 of them are 150 only, but Trendnet should be 300... still nothing happens.
I reset the router 2 times, once 30/30/30 and once normal reset, and reinstalled 68 manually.. No changes.
The only way I can use this router wireless is only in G/54mbps...
Wired I have no issue and have 34mbit up and down (I pay for 30/30
What the h*** can I do to setup this router properly.
Or what good USB adapter can let me have N connections?
I have had other Netgears, Linksys, but this 3700 is a mistery for me.
Regards
Adapters are:
Regards
