WTR-DD Firmware with Netgear R7000
leehop71
Can the WTR-DD Firmware be used with the Netgear R7000 router?
If so, is there a download and install instructions somewhere?
To cut a long story short, DD-WRT has its own wiki (for flashing follow the wiki) and its own web forum.
DD-WRT is called a Cadillac, not a Porsche, because speed is not its main concern (divide processor speed in MHz by 4.5 and you get expected maximal DD-WRT download speed in Mbps).
Stick with Kong builds, they are fairly well tested. In DD-WRT land newer does not always mean better (occasionally it means that you have to unbrick your router).
Backup your bootloader and NVRAM settings, they might come handy later.
