X86U consume so much ...
pl4tin
Hi I bought a new router last Wednesday and install a Merlin firmware, and I notice that it consumes so much resources. I do a reboot in the morning and I have 83% ram used ,8h later I have 94%, it's normal?
You scared me, buddy. I was thinking alcohol consumption.
Realized one of my 86Us is close to the bar. Went to check right away. o_O
I've done a reset with no settings save 3h ago, until now it's above 80%. let's wait to see a little more
The moment you start file transfers your memory use will jump to 95%. Cache and buffers.
You're right, I'm do a test with my hdd and the ram goes up. Ok and now, after finishing use hdd, do I need reboot router to update the ram?
^^^ Ditto, Linux typically uses most "unused" pRAM for it's OS buffers and cache. They figure, it's sitting there, use it. It will give it back if a process needs it. Now if you see a process constantly growing larger and larger ... that's a memory-leak worry. Peace.
C Extreme Hack That Got Much Worse After Reflashing Asuswrt-Merlin 27
