xdsl modem recommend it??
gabox
Hi, I'm looking for a device to operate as a xDSL modem in bridge mode, in other words, a separate xdsl modem connected via LAN to Asus RT-ac68u do everything else starting with PPPoE. Which modem do you recommend me ?
thanks a lot.
i can only comment on what we have found here in australia
define what type of dsl its needed for as
adsl
on short lines the tp link td w8817
on lone lines tp link td w8960N
short is under 2.5km from exchange or under 35db attenuation
on vdsl2
linksys x6200
ASUS DSL-AC52U
Thanks. yes, just i use adsl on bridge mode. What Hardware Version is better to td w8960N ?
Td-w8961nd is good ? am i able to configure TD-W8960n/W8961nd as modem Bridge to Asus Rt68u call it PPPoE (user/pass) ?
thanks
thanks a lot @pete y testing I am going to buy a w8960n. Here in Argentina there is version 6
Kind regards.
