Xiaomi Tri-Band Mi AX9000
psychopomp1
Reviews seem to be great and specs (on paper at least) look high end:
Hardware configuration
Processor: Qualcomm IPQ8072 quad-core A53 2.2GHz
Network processing unit: Dual core 1.7GHz
Memory: 1 GB
Wi-Fi 2.4G: 4 × 4 (supports up to IEEE 802.11ax protocol, theoretical maximum rate is 1148 Mbps)
Wi-Fi 5GHz-1: 4 × 4 (supports up to IEEE 802.11ax protocol, theoretical maximum rate is 4804 Mbps)
Wi-Fi 5 Ghz-2: 4 × 4 (supports up to IEEE 802.11ax protocol, theoretical maximum rate is 2402 Mbps)
Antennas: High gain external antenna + internal AIoT antenna
Heat dissipation: Active cooling
Total ports:
1x 10/100/1000/2500 Mbps adaptive WAN / LAN port (Auto MDI / MDIX)
1x 10/100/1000 Mbps adaptive WAN / LAN port (Auto MDI / MDIX)
3x 10/100/1000 Mbps adaptive LAN ports (Auto MDI / MDIX)
LED lights: 8 lights, including system indicator, Internet indicator, network port, atmosphere light
Interface:
1x System reset button
1x USB 3.0 port
1x Mesh Net Button
1x Power button
1x Power input port
Protocol standards: IEEE 802.11a / b / g / n / ac / ax, IEEE 802.3 / 3u / 3ab
Wireless connection
Tri-band: 2.4 GHz, 5 GHz-1 and 5 GHz-2
Modulation:
11b: DSSS: DBPSK (1 Mbps), DQPSK (2 Mbps), CCK (5.5 / 11 Mbps)
11a / g: OFDM: BPSK (6 / 9Mbps), QPSK (12 / 18Mbps), 16QAM (24 / 36Mbps), 64QAM (48 / 54Mbps)
11n: MIMO-OFDM: BPSK, QPSK, 16QAM, 64QAM. Data rate: MCS0-MCS15
11ac: MIMO-OFDM: BPSK, QPSK, 16QAM, 64QAM, 256QAM
11ax: MIMO-OFDM: BPSK, QPSK, 16QAM, 64QAM, 256QAM, 1024QAM
Data rates: MCS0-MCS11 (supports 4 streams) .4096QAM
Data rates: MCS12-MCS13 (supports 2 streams)
Software parameters
Operating system: MiWiFi ROM, an OpenWRT-based smart router operating system
WiFi encryption: WPA-PSK / WPA2-PSK / WPA3-SAE encryption, wireless access control (black and white list), SSID hidden
Management applications: Supports Web, Android, iOS
Operating environment
Operating temperature: 0-40 ºC
Operating humidity: 10% -90% RH (non-condensing)
Storage temperature: -40-70 ºC
Storage humidity: 5% -90% RH (non-condensing)
It can be bought for less than £200 in Europe, around 50% the cost of a comparable router from Netgear (RAX200). My only concern is lack of English firmware, though I believe there is a global version of the router with English fw. Does anyone know if fw will come in English if i buy from Europe? This is where I'm thinking of buying it from (I'm in UK):
Cheers
Here it is in flight configuration:
Ha ha even better you can use it to cook stuff
But on a serious note, I have ordered it from that Spanish retailer for GBP 195, I should have it next week. I will post feedback by comparing it to my Netgear RAX200 wrt performance.
Looks good on specs, but you may get few firmware updates only. The price is right, if it works as promised.
D ASUS RT-BE92U WiFi 7 Tri-Band 9700Mbps 10gb extender help Wi-Fi Buying Advice 2
