XT8: How do I turn off LED on node?
crawfish
I've just set up my new 2 piece XT8 system and configured for AIMesh. I configured the WPS button to turn the LED on and off, but it only works on the router unit. Any idea why it doesn't work on the node, or any suggestions as to how to control the node's LED?
ETA: I found "LED" in the web UI under AiMesh/Management. Never mind!
if your units are black I used a small piece of electric tape to cover the LED, problem solved. I don’t think there is a setting that controls the LED on the node.
I apparently updated my post as you were writing yours. There is a setting to turn off the LED on a node!
BTW, if you ever want to dim an LED you can't control, there's a product called "Light Dims" which are an adhesive film that comes in various sizes and shapes.
The smart phone app makes this very easy...just start at "Home", and tap on the node that you're concerned with in the network graph you'll see there. The first setting that you'll see in the next window for the node is "LED Settings", and just hit the toggle there, and bob's your uncle. Very convenient, and you can do it anywhere that you are with your phone *smile*.
