XT8 purchase advice
chrisnasah
Hello
I am looking to upgrade wireless at home and deciding on XT8 but wanted someone to confirm some details if possible.
As I will be running them in AP mode, will I be able to create a Guest SSID?
Is it possible to assign a tagged VLAN for guest access?
Hello
From what I understand, a guest WLAN on a traditional wired AP is not isolated from the router clients. And VLANs are not supported.
But wait for someone else to chime in here.
OE
I believe @OzarkEdge is correct. Not possible unless you want to deep dive into scripts.
Hello
Yes, you can create 4 guest ssids for each band, and isolated from the rest of your LAN and each others. I think you don't need vlan for that purpose:
Might want to check on availability.
Amazon in UK hasn't had stock for months.
May or May not be related to wifi 6e or covid.
