XT9 poor range
Gm2000
Hi
I’ve just bought a pair of XT9’s and the range is significantly worse than the Sky SR209 that it replaces.
I will need 3-4 ai mesh nodes to replace a single router in my 3000 sq ft property.
In every other respect they are a big improvement except wireless range. Any suggestions?
Where are you (generally) and from where did you get them? If they match your locale and unless you've got highly opaque-to-wifi walls / floors, it's likely a (mis)configuration issue. A pair of those should easily bathe that much area in wifi.
