YazDHCP YazDHCP v1.2.4 [2025-Nov-21] - Feature expansion of DHCP assignments (increasing limit on the number of DHCP reservations)
Another feature would be nice when someone saves icons to offer download outside of the router for backup.
The backup and restore custom icons can be or is backed up to a USB drive attached to the router. Once saved to the USB drive you should be able to access that storage location to copy the backup somewhere else. While in the GUI, creating a compressed file and offering the user a dialog screen asking them where to save it or to upload it for importation would be a nice feature, under the current implementation the user can copy the backed up file somewhere else, just takes one or two extra steps.
https://github.com/AMTM-OSR/YazDHCP?tab=readme-ov-file#back-up--restore-custom-user-icons
"Back up & Restore" custom user icons​
You can save a backup of the custom user icons found in the "/jffs/usericons" directory, and you can later select one of the backup files to restore the icons files as needed. The command line interface allows you to change the directory path where the backup subdirectory is located, and you have option to delete backup files, or list the contents of a backup file. The default maximum number of backup files to keep is 20, but you can change this maximum setting (between min=5 to max=50) using the CLI menu.
NOTES​
  1. The current implementation of the "Back up & Restore" of custom user icons does NOT export to or import from an external PC or client device connected to the router. Instead, it targets a directory available either on the router's JFFS partition or in a USB-attached disk drive. This target directory is where the subdirectory for backups is created and can be modified using the CLI menu (see note #3 below).
  2. The CLI main menu option 2 for the "Back up & Restore" functionality will show up only if there is at least one custom user icon file found in the "/jffs/usericon" directory, or if at least one backup file is found in the directory path defined for backups. If none of those 2 conditions is met, the option 2 will not show up in the main menu.
  3. To start using the "Back up & Restore custom user icons" feature, it's highly recommended to set the target directory where the subdirectory for backups is to be located (see option "dp" in the CLI menu). For the backups subdirectory to survive a "Factory Defaults Reset" of the router, it's highly recommended to use a directory path located on a disk drive plugged in to one of the router's USB ports. You don't have to have Entware installed on the USB-attached disk; any USB disk drive formatted with either NTFS or ext4 is sufficient to use as storage for the backup files.
The think that some of us do not have USB drives attached to the router, it would be nice, if possible, to download icons file when it is created. I do not know if it is hard or not, but it is the function of a browser in general.
Is the above functionality something that users would like to have available?
For me, if it means (what I think it means) i.e. doing away with the manual /jffs/config/dnsmasq-x.conf.add then it is a resounding YES. I would love this feature!
I know GNP does have manual assignments but as per my responses to one of the Merlin 3006.102.xx threads, I quickly hit the limit of numbers of these reservations well before the supposed 'formal' limit of 32, so I think 3006 would also benefit greatly!
Apologies for the delayed reply. I've been very busy with my day job and other personal stuff, so I didn't have time until this weekend.
Anyway, thanks to those who provided feedback WRT adding a new feature to allow IP address reservations for clients on suitable Guest Networks. Some friends of mine and relatives have also expressed interest in having that feature available.
For 3006 firmware, other than duplicating the feature from elsewhere it may be usefull to add this to YazDHCP, even if it's just to centralise everything. For 3004 no question - a big fat YES!
Beta tester ready! 😁
For simplicities sake, such inclusion would have been fantastic on the 3004.x Asus-Merlin firmware running YazFi. Would have saved the extra step of having to have two files to backup and restore, the YazDHCP file and the YazFi's manual reservation /jffs/scripts/dnsmasq.postconf file. And, I assume such a feature would allow for the YazFi user to create and enter new manual YazFi client reservations directly into the LAN DHCP Server manual reservation section.
Yes, that's the intended goal. Any available Guest Network that's currently enabled/active with a separate subnet from the Main LAN subnet would be allowed to have manually-assigned DHCP IP address reservations for its clients on the YazDHCP webUI page.
Also, having a single webUI page to assign all IP address reservations (within a limit - see below), where the "backup and restore" functionality is also available, would be one of the big advantages, as other people have mentioned.
I know GNP does have manual assignments but as per my responses to one of the Merlin 3006.102.xx threads, I quickly hit the limit of numbers of these reservations well before the supposed 'formal' limit, So I think 3006 would also benefit greatly!
Note that there is a hard limit (about 8KB, IIRC) on how much data can be passed between the webUI page and its shell script (AFAIK, this limit is imposed by the RMerlin F/W). So the total number of possible IP address reservations that gets displayed on the webU page is dynamically calculated as each entry is saved, based on the average length of all current entries. Given this limitation, the recommendation is to keep all Hostname strings short - about 10-12 chars each - so you don't exhaust the limited storage with only a few dozen entries.
I'm going to start working on it Sunday evening, and perhaps I can have a beta-stage development version after a few evenings of coding.
Awesome to hear it’s going to take shape and really appreciate you taking this on. Seems a lot of work, so all the more thanks!
Not my call obviously, but I’m sort of undecided on the merits of one big long list for ALL the reservations, Primary and each VLAN, if that’s what is proposed. Sort of wondering if a separate tab for each VLAN on GNP would be neater? Be interested to hear other folks thoughts on this.
Would think it would almost have to be done that way. Some sort of tabs, or separator, or delineation between networks of the DHCP reservation list so users are not confused and assigning clients to the wrong network.
I'm not planning to drastically change the current JavaScript + HTML code in the ASP file used by YazDHCP (which is essentially a modified copy of the native ASP file provided originally by the F/W). I want to make as few changes as possible there, and instead have the shell script do the bulk of the work. So, at this point, new, separate tabs on the webUI are not part of the plan.
Frankly, I don't see the need to have a separate tab or some kind of separator for each Guest Network. When users want to assign an IP address reservation to a client, they really need only 2 pieces of information: the client's MAC address and the specific IP address they want to assign to it. If the client is already connected to the network (or has been in the recent past - see "Offline Client List"), there is an entry for it in the drop-down menu available on the webGUI page:
Example screenshot:
This drop-down menu can be used to select the client, and then you can enter the desired IP address (if different), and optionally input its Hostname plus the DNS server IP address. It's a very simple and straightforward method to follow, IMO. At this point, I see no need to make things more complicated for the new feature. If you don't know the specific Guest Network subnet for the IP address, you can look for it in the YazFi webUI page (if that's installed), or in whatever Guest Network setup/configuration page is available.
To be clear, nothing has been written in stone, since I have not yet started coding it, but I do already have a preliminary layout of the execution and data flow and a list of functions to implement. But that's where things stand this evening.
My 2 cents.
It will likely come down to usability once you have something for people to play with and test out. What ever the case, should be a great feature addition for users. :)
Is there a way to install the develop 1.0.7 (https://raw.githubusercontent.com/jackyaz/YazDHCP/refs/heads/develop/YazDHCP.sh) build offline?
As in no WAN connection to the internet.
It seems to want to download shared-jy.tar.gz from https://jackyaz.io/shared-jy/master, but that seems to no longer exist. I noticed that shared-jy.tar.gz is now at https://github.com/jackyaz/shared-jy/blob/master/shared-jy.tar.gz
So I copied that over to: /jffs/addons/shared-jy/shared-jy.tar.gz
Then ran the install, but sadly it shows this:
##  __     __          _____   _    _   _____  _____    ##
##  \ \   / /         |  __ \ | |  | | / ____||  __ \   ##
##   \ \_/ /__ _  ____| |  | || |__| || |     | |__) |  ##
##    \   // _  ||_  /| |  | ||  __  || |     |  ___/   ##
##     | || (_| | / / | |__| || |  | || |____ | |       ##
##     |_| \__,_|/___||_____/ |_|  |_| \_____||_|       ##
##                   v1.0.7 on RT-AC88U                 ##
##           https://github.com/jackyaz/YazDHCP         ##
Welcome to YazDHCP v1.0.7, a script by JackYaz
Checking if your router meets the requirements for YazDHCP
**INFO**:  Backup directory [/opt/var/SavedUserIcons] NOT FOUND.
Trying again with directory [/jffs/configs/SavedUserIcons]
*WARNING*: Alternative Backup directory [/jffs/configs/SavedUserIcons]
YazDHCP will backup NVRAM/JFFS DHCP data as part of the export,
but you may wish to screenshot the following WebUI page:
http://IP/Advanced_DHCP_Content.asp
If you wish to screenshot, please do so now before the WebUI page is updated by YazDHCP.
Press the <Enter> key when you are ready to continue...
curl: (6) Could not resolve host: jackyaz.io
New version of Advanced_DHCP_Content.asp downloaded
Mounting WebUI tab for YazDHCP
mount: mounting /jffs/addons/YazDHCP.d/Advanced_DHCP_Content.asp on /www/Advanced_DHCP_Content.asp failed: No such file or directory
WebUI tab for YazDHCP was mounted.
New version of shared-jy.tar.gz downloaded
Do you want to export DHCP assignments and hostnames from NVRAM to YazDHCP DHCP client files?
YazDHCP will backup NVRAM/JFFS DHCP data as part of the export process.
Enter answer (y/n):  y
DHCP information successfully exported from NVRAM
DHCP hostname list unchanged
DHCP static assignment list unchanged
DHCP options list unchanged
Restarting dnsmasq for exported DHCP settings to take effect.
YazDHCP installed successfully!
But the router's Advanced_DHCP_Content.asp page is still the normal page.
I guess that the error of "mount: mounting /jffs/addons/YazDHCP.d/Advanced_DHCP_Content.asp on /www/Advanced_DHCP_Content.asp failed: No such file or directory" is to blame.
RT-AC88U with Firmware: 386.14_2 - I know it's old, hence why not on WAN ATM.
I also tried the build from https://github.com/AMTM-OSR/YazDHCP and I basically have the same problem.
Thanks for the assistance,
Will
Well seems I can't edit, too bad.
Said F it, got it back online temp:
will@RT-AC88U-CDF8:/tmp/home/root# nslookup google.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 2607:f8b0:4004:c1d::8a ww-in-f138.1e100.net
Address 2: 172.253.63.102 bi-in-f102.1e100.net
Address 3: 172.253.63.113 bi-in-f113.1e100.net
Address 4: 172.253.63.139 bi-in-f139.1e100.net
Address 5: 172.253.63.101 bi-in-f101.1e100.net
Address 6: 172.253.63.100 bi-in-f100.1e100.net
Address 7: 172.253.63.138 bi-in-f138.1e100.net
will@RT-AC88U-CDF8:/tmp/home/root# ping google.com
PING google.com (172.253.62.138): 56 data bytes
64 bytes from 172.253.62.138: seq=1 ttl=108 time=9.820 ms
64 bytes from 172.253.62.138: seq=2 ttl=108 time=10.704 ms
64 bytes from 172.253.62.138: seq=3 ttl=108 time=9.612 ms
64 bytes from 172.253.62.138: seq=4 ttl=108 time=8.514 ms
64 bytes from 172.253.62.138: seq=5 ttl=108 time=10.506 ms
^C
--- google.com ping statistics ---
6 packets transmitted, 5 packets received, 16% packet loss
round-trip min/avg/max = 8.514/9.831/10.704 ms
But it fails:
##                v1.0.10 on RT-AC88U                   ##
##         https://github.com/AMTM-OSR/YazDHCP          ##
##    Forked from https://github.com/jackyaz/YazDHCP    ##
Welcome to YazDHCP v1.0.10, a script by JackYaz
curl: (60) SSL certificate problem: certificate is not yet valid
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
tar: can't open '/jffs/addons/shared-jy/shared-jy.tar.gz': No such file or directory
Was about to send that.
Then realized:
date
Sun Dec 31 19:13:40 EST 2023
NO wonder.
ntpd -q -p pool.ntp.org
will@RT-AC88U-CDF8:/tmp/home/root# date
Sat Aug 30 19:52:01 DST 2025
Much better, and what do you know, it worked. Thanks! - Cable pulled. Hopefully didn't get hacked in the less than 5 mins it was on the internet, ha.
It's behind 2 other firewalls, so not that worried. And no ports forwarded or anything like that.
Figured I'd post in case someone else runs into this. But yeah, an offline install option would be ideal. Anyways, it's working. TY!
Will
Let me start with there is always a way if your determined enough.
However i would really need to just recommend you connect it to the internet for a second to do the install, it's the easiest way.
I realize you have your reasons to keep it offline, but connecting it to your primary routers LAN for just a moment should give you internet access to do the install, without putting the old routers WAN's interface directly on the internet.
Basically a temporary dual NAT setup just to get it connected for a minute or two, the chances of any risks behind the primary router's LAN is basically null unless your already compromised on your primary LAN network.
Now if your still determined to do it your way, you need to comment out the following 2 lines:
Server:    127.0.0.1
^C
But it fails:
Then realized:
date
NO wonder.
Jinx!
FYI,
Significant progress has been made regarding a new YazDHCP feature to allow assigning DHCP IP address reservations to clients on available Guest Networks whose subnet range is separate from the main LAN subnet. Today, I got the full process working on my test router (RT-AC86U) running the 3004.386.14.2 F/W. A friend of mine already downloaded my local development version (*not* in my personal GitHub repo yet) to run some initial testing on his RT-AX86S router.
Some sample screenshots:
1) Feature is UNAVAILABLE when no suitable Guest Networks are found.
2) By default, the feature starts as DISABLED when at least one suitable Guest Network is found.
3) Here is a mix of clients from the main LAN and from 2 separate Guest Networks.
4) Here is the exported CSV file from the client list.
5) Option to ENABLE/DISABLE the feature using the SSH CLI menu:
The next phase is to make it work on the 3006.102.5 F/W. This part will likely go at a slower pace since my main network router (RT-AX86U_PRO) cannot be taken offline at all during the day for testing/development purposes (my wife and I work from home a few days a week), and in the evenings I run the risk of "sleeping in the dog house" :eek:;)😜 if I interrupt the network for any reason.
Anyway, just some FYI about the progress being made. No ETA at this time for a Beta release. If I have to make a guess, I would say somewhere around 2-3 weeks. I do most of this dev. work over the weekends (when everyone is outside the house), and late at night (when everyone is asleep).
I have just one reservation. I have already defined manual IPs for IoT devices in GNP. Would your addition to YazDHCP ignore these, adopt these, or disable them? Or would YazDHCP just fall over?
Made a similar observation previously in this discussion on the issue of the 3006 GNP manual reservations in the interface.
Such a feature on the 3006 firmware and it's Guest Network Pro Profiles would also be useful but likely far more complex to program due to VLAN/SDN's on the 3006.x firmware and it's manual reservation setting under the Guest Network Pro Profile that gets saved to NVRAM versus using a dnsmasq-INDEX.conf.add or dnsmasq-sdn.postconf file. But it would still be extremely useful to be able to input all the manual reservations in one place and be able to backup and restore them.
Hopefully a way can be coded to pull the GNP manual IP reservation NVRAM values and include them in the YazDHCP process for those who choose use the manual GNP GUI reservation method over the dnsmasq-INDEX.conf.add or dnsmasq-sdn.postconf file method.
YazDHCP will just stumble and fall over, of course. That's the intended plan… ;)😆😜 LOL!!!
But seriously, the part about migrating current GN IP address reservations from NVRAM to YazDHCP internal files is already working in both 3006 & 3004 F/W. That's one of the first functions I wrote from the start to make sure I could restore the original settings when uninstalling the add-on.
A lot of the initial "plumbing" and "wiring under the hood" is already in place to support the implementation for the 3006 F/W. For example, each of the Guest Networks gets its own set of internal files to store the associated dnsmasq directives. This is done regardless of the F/W version installed.
The goal is to decouple, or maintain very loose coupling between, most of the code and the final intended target. It’s only at the very end that the individual files are either consolidated into a single file for dnsmasq under 3004, or will be kept separate under 3006 to target the dnsmasq instance associated with each Guest Network setup.
Release Notes for YazDHCP v1.2.0 Development Version
[BETA v1.2.0_25091923] [2025-Sep-20]
To update from the currently installed production version to the latest 1.2.0 Beta development version, run the following command on an SSH terminal session:
Bash:
/jffs/scripts/YazDHCP develop
/jffs/scripts/YazDHCP forceupdate
This is the 1st BETA development version of YazDHCP 1.2.0, which introduces a new feature to allow users to manually assign DHCP IP address reservations to clients on any available Guest Network whose subnet is separate from the main LAN subnet. See below for more details.
When reporting any issues, please provide readable screenshots as well as all relevant information regarding the Guest Network that appears to show the problem/bug being reported. I'll try to reply within 24 to 48 hours.
DETAILS:
- When the YazDHCP 1.2.0 Beta development version is a fresh installation (*not* a version update), the script automatically checks if there are any DHCP IP address reservations stored in NVRAM. If found, it will prompt the user to confirm exporting all the existing reservations from NVRAM to YazDHCP internal files. This export process extracts all the relevant information to create the initial list of network clients from both the Main LAN and the Guest Networks (if any). Also, it allows users to restore the same IP address reservations to their original NVRAM state if you decide to uninstall YazDHCP at a later time.
- If a current production version of YazDHCP is already installed, updating to the latest 1.2.0 Beta development version will add an option 'x' in the SSH CLI menu to export any existing DHCP IP address reservations stored in NVRAM (if found). If this option is selected, the same export process triggered during a fresh installation will run.
- After the export of the NVRAM information is completed, any existing IP address reservations from Guest Networks will be shown as DISABLED (i.e. red background). Also, by default, if at least one suitable Guest Network is found enabled/active, the new feature is set to DISABLED, so the original behavior & functionality continues to run as usual.
- If at least one suitable Guest Network is found enabled/active, you will need to manually ENABLED the feature to activate all the Guest Network IP address assignments and to allow the user to input more entries. Make sure to click on the "Apply" button at the bottom of the WebUI page to make any changes permanent.
- After a Guest Network client IP address reservation is assigned, it will not be automatically removed from the WebUI page even if the feature is manually DISABLED, or if the Guest Network is temporarily DISABLED. However, the files associated with the dnsmasq instance will have the Guest Network client entries removed automatically.
- The menu option to toggle the new functionality will be grayed out and marked as UNAVAILABLE if there are no enabled Guest Networks whose subnet is separate from the main LAN subnet.
- You can manually add IP address reservations to Guest Network clients as long as the target Guest Network remains enabled and active.
- When assigning a new IP address reservation, the code will check if it falls within the subnet range of an available Guest Network in addition to the main LAN subnet; otherwise, an error message is displayed.
Have fun with it!! ;):)
@Martinski, haven't installed the beta yet, but do have a question. For the Guest Network Pro profile IP reservations, does the Beta only pull those reservations from NVRAM? Or does the Beta also check and pull the reservations from dnsmasq-INDEX.conf.add or dnsmasq-sdn.postconf file if those are used for the manual reservations instead of using the Guest Network Pro profile's Manually assigned IP around the DHCP list option (which are saved to NVRAM)?
