YazFi YazFi 4.4.2 Dns Leak After Update AX-88U (surfshark Vpn)
Asusrouterlover
Hi
I Just Update to version 4.4.2 YazFi and I have Dns Leak After This Update
every thing Was Work Fine With Defulet Yazfi setting 4.4.1 Dns 8.8.8.8 And 8.8.4.4
i use surfshark vpn for my guest network with smart dns enable
can some one help
Not too familiar about how openVPN works, so I dont know how much help I will be.
1) How is your setup intended to work?
2) what's your vpn dns setup?
3) how are you testing for leaks?
4) any other type of dns you have setup? Stubby, Unbound et.c?
5) have you tried: Reboot? Restart vpn connection?
Perhaps the output of:
iptables -nvL PREROUTING -t nat
iptables -nvL YazFiDNSFILTER -t nat
Will provide some info about what is happening.
Normally YazFi provides "Exclusive" dns setup were firewall rules are redirecting clients to the dns you enter in gui which superseeds the router dns-filter.
//Zeb
Vpn Access Without Dns Leak
i use YazFi Setup i dont change any thing
ipeak.net
nextdns for home use
yes
What firmware version is being run on the AX88U?
Hi
can some one help
Make sure your VPN server is set like this
report back if this fixes your issue.
Also make sure any custom DNS used in Surfshark VPN are not overriding your options specified by YazFi
Both of these not set correctly could be resulting in your DNS leak.
(This is assuming you are intending to use 8.8.8.8 and 8.8.4.4, which is what your post sounds like. )
*** Browser Cache just caught up, Just realized this has been dealt with, disregard and carry on***
just restart the router every thing work fine again
thanks for tip
