ZenWifi AX crashlog on firmware version 3.0.0.4.386_41793-gdb31cdc
RogerSC
Part of the Furniture
Was just looking through the system log on my ZenWifi AX tonight, and noticed that it had only been up for 1 day, 10 hours, when it should have been up longer. Looked at what was in the log for that time, and saw this:
Feb  9 14:58:28 roamast: Roam a client [78:7B:8A:3B:C2:53], status [0]
Feb  9 14:58:28 wlceventd: wlceventd_proc_event(507): eth5: Disassoc 78:7B:8A:3B:C2:53, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Feb  9 15:17:28 wlceventd: wlceventd_proc_event(526): eth5: Auth A8:81:7E:A2:DE:45, status: Successful (0), rssi:0
Feb  9 15:17:28 wlceventd: wlceventd_proc_event(536): eth5: ReAssoc A8:81:7E:A2:DE:45, status: Successful (0), rssi:0
May  4 22:05:13 crashlog: LOG
May  4 22:05:13 crashlog: <4>
May  4 22:05:13 crashlog: <4>90:CD:B6:98:E2:A3 not mesh client, can't update it's ip
May  4 22:05:13 crashlog: <7>[tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
May  4 22:05:13 crashlog: <6>CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
May  4 22:05:13 crashlog: <4>84:AB:1A:89:E0:98 not mesh client, can't update it's ip
May  4 22:05:13 kernel: klogd started: BusyBox v1.24.1 (2021-01-18 14:05:07 CST)
I'm not up enough on what's in mesh router system logs to see if this contains a clue as to what happened...This is relatively new firmware, looks like I installed it about Feb. 3, so I'm wondering if I should revert it to the previous firmware? I didn't notice the crash, so the router must have recovered fairly quickly from whatever caused it to crash.
Not sure if this: "90:CD:B6:98:E2:A3 not mesh client, can't update it's ip" has any significance relative to the mesh router crashing or not. It doesn't sound great, since all my clients are mesh clients *smile*. But it is the first significant thing in the crashlog, so it might.
Anyways, any help here about what might be going on? Very happy with the performance of the mesh, but this has me wondering.
It did just occur to me that I didn't reset the routers to factory defaults and reconfigure when I did the last upgrade of firmware which included the upgrade to AiMesh 2.0, maybe I should try that and see if that helps the stability. Just not sure what I'm seeing here.
A few have reported spontaneous reboots, but after a couple of them, the system has been running stable.
Maybe, when I reboot (via the GUI) at 15 minutes and again after an additional 60 minutes after flashing new firmware, the networks I oversee are more stable?
You may want to monitor it and see if it crashes/reboots again. That may be the time to do a full reset.
If it's working now, I don't see the immediate need to do so. :)
Decided to go with the "nuclear option." Went back to previously stable firmware, pre-AiMesh 2.0. Reset both nodes and reinstalled and reconfigured them from scratch. Since my return window closes in about 10 days, I want to make sure that I can avoid the "spontaneous reboots" for a few days. Anyways. I'll be keeping a closer eye on the system log to look for reboots.
Due to the great performance I'm not seriously entertaining returning these at this point, but who knows how I'll feel in a week *smile*.
