ZenWiFi BT8 keeps dropping clients and error in log
BobWadd
I've been running a AiMesh system with a RT-BE96U as the router with two ZenWiFi BT10s and one ET8 as the nodes without issue for about a year now.
Today I changed the ET8 to a BT8 and started having issues. The BT8 works fine for a little bit then all of a sudden drops all clients. After a while clients will reconnect, and things will be fine again. It then proceeds to drop clients again after a short time. And it continues in this cycle.
I've also noticed that while the clients are connected total client count is correct. When the BT8 drops client's total client count continues to rise and is really all over the place until they reconnect, then it shows the correct count again.
I realize the connection to the BT8 is weak, but the weak signal was never an issue with the ET8. I will be hardwiring the node as soon as I have time.
There are also errors in the log as shown below:
Oct 25 22:11:36 dnsmasq-dhcp[1059]: DHCPREQUEST(br0) 192.168.0.30 d6:02:02:5c:d4:09
Oct 25 22:11:36 dnsmasq-dhcp[1059]: DHCPACK(br0) 192.168.0.30 d6:02:02:5c:d4:09 Watch
Oct 25 22:11:36 kernel: Can't add zero mac!
Oct 25 22:11:36 kernel: 192.168.0.65 is used by someone else, can't use it
Oct 25 22:11:36 kernel: 192.168.0.221 already exist in UDB, can't add it
Oct 25 22:11:36 kernel: 192.168.0.221 is used by someone else, can't use it
Oct 25 22:11:36 kernel: D6:02:02:5C:D4:09 not mesh client, can't update it's ip
Oct 25 22:11:44 bsd: bsd: wl0.1 Sending act Frame to c8:15:4e:70:89:24 with transition target wl1.1 ssid 72:9c:25:8f:c3:d5
Oct 25 22:11:44 bsd: bsd: BSS Transit Response: ifname=wl0.1, event=156, token=11, status=7, mac=dd:07:50:6f:9a:16
Oct 25 22:11:44 bsd: bsd: BSS Transit Response: STA reject
Oct 25 22:11:44 bsd: bsd: Skip STA:c8:15:4e:70:89:24 reject BSSID
Oct 25 22:12:58 dnsmasq-dhcp[1059]: DHCPREQUEST(br0) 192.168.0.30 d6:02:02:5c:d4:09
Oct 25 22:12:58 dnsmasq-dhcp[1059]: DHCPACK(br0) 192.168.0.30 d6:02:02:5c:d4:09 Watch
Oct 25 22:12:58 kernel: Can't add zero mac!
Oct 25 22:12:58 kernel: 192.168.0.65 is used by someone else, can't use it
Oct 25 22:12:58 kernel: 192.168.0.221 already exist in UDB, can't add it
Oct 25 22:12:58 kernel: 192.168.0.221 is used by someone else, can't use it
Oct 25 22:12:58 kernel: D6:02:02:5C:D4:09 not mesh client, can't update it's ip
Oct 25 22:13:08 dnsmasq-dhcp[1059]: DHCPREQUEST(br0) 192.168.0.30 d6:02:02:5c:d4:09
Oct 25 22:13:08 dnsmasq-dhcp[1059]: DHCPACK(br0) 192.168.0.30 d6:02:02:5c:d4:09 Watch
Oct 25 22:13:08 kernel: Can't add zero mac!
Oct 25 22:13:08 kernel: 192.168.0.65 is used by someone else, can't use it
Oct 25 22:13:08 kernel: 192.168.0.221 already exist in UDB, can't add it
Oct 25 22:13:08 kernel: 192.168.0.221 is used by someone else, can't use it
Oct 25 22:13:08 kernel: D6:02:02:5C:D4:09 not mesh client, can't update it's ip
Oct 25 22:14:37 rc_service: cfg_server 4849:notify_rc stop_fw_check
Oct 25 22:14:37 custom_script: Running /jffs/scripts/service-event (args: stop fw_check)
Oct 25 22:14:38 rc_service: cfg_server 4849:notify_rc start_fw_check
Oct 25 22:14:38 custom_script: Running /jffs/scripts/service-event (args: start fw_check)
Oct 25 22:14:49 bsd: bsd: wl0.1 Sending act Frame to c8:15:4e:70:89:24 with transition target wl1.1 ssid 72:9c:25:8f:c3:d5
Oct 25 22:14:49 bsd: bsd: BSS Transit Response: ifname=wl0.1, event=156, token=12, status=7, mac=dd:07:50:6f:9a:16
Oct 25 22:14:49 bsd: bsd: BSS Transit Response: STA reject
Oct 25 22:14:49 bsd: bsd: Skip STA:c8:15:4e:70:89:24 reject BSSID
Any help would be greatly appreciated.
TIA, Bob
