Zyxel HLA4205 questions with Gig internet
elChango
I've bought two of these to run wired from the router to the home office. To test out I ran brand new RG6 cable in between both units. I'm only hitting this speed. 450/484
http://frontier.speedtestcustom.com/result/84d86240-abc2-11ea-abaf-cd38ab46d171
Tried the RG6 cable in the wall, same thing 450/484. I ran a 100 foot cat 5e cable directly from the router to the computer and got the 940 mb/sec and 860 mb/sec.
anyone have experience with the units? I've tried getting on the built in gui it doesn't find the ip. 192.168.1.3
Router -> Ethernet cable -> Moca adapter -> RG6-> Moca Adapter -> Ethernet Cable -> Computer.
is there a setting within the units to change the speed?
Thank you.
edit: ran iperf on 3 different machines - Just the moca adapters and RG6 cable inbetween the computers.
I use these and work great, but be aware that for iperf3 testing you can only achieve the highspeed with parallel mode. Try with the -P parameter and maybe 5 streams.
