I noticed a weird problem with two of my Asus routers. I do run an AX-68 (with Merlin) on the basement. Furthermore, I also have an AC-59U V2 on the first floor and another on the second floor. The two AC-59U work as Access Point. After a blackout today, I restarted all devices (but only the AC-59U at first floor was affected by the blackout). With the AX everything is fine. The two AC are reachable via ping without issue. The gui is accessible at the login screen. Trying to log in on either of the two AC-59U leads to a long delay (several minutes) and then ends up at the login screen again. I tried rebooting all routers, the managed switches, tried several browsers, emptied the cache, tried http://ip ...
Nothing worked.
Any ideas?
Nothing worked.
Any ideas?
