ASUS iOS app not finding router AX89U Pro 3.0.0.6.102_21514
kalomato_
Hi!
New Asus AX89U Pro with 3.0.0.6.102_21514 firmware. Configured and running.
Asus Router App 1.0.0.8.33 in iOS 17.1.1
Asus router app does not find AX89U router to connect and manage from App. So I'm not able to do it.
I select "Manage a connected router", but app show a screen:
"1. Open your mobile device's wireless settings
2. Find and connect to your ASUS router's SSID
3. After successful connection to the SSID, return to Asus Router App"
And of course I'm connected to the router's SSID, and app has permission to access LAN.
I already uses app to manage my previous router with no problem.
I can connect from muy computer via https (8443).
I tried to reinstall App and enabled HTTP (80) access to the router.
Do you know if Asus Router app is compatible with firmware 3.0.0.6.102_21514?
Are anyone with same firmware version able to connect app to the router?
Or may be another problem that I don't know?
Best regards.
GT-AX6000 with the same ver of firmware is connected with ASUS app in iOs 16.7.2 (when I buy new phone then I will try the new iOs )))
Thanks!
Finally I'll return AX88U Pro; too may failures with both firmwares (3.0.0.4.388 and 3.0.0.4.102); Not detected by Asus router App, Wifi 5Ghz suddenly disappears, even during last hours wifi 5Ghz only appears at startup and disappears 1 minute later for ever.
Perhaps I had bad luck with this unit.
Regards
There is a different Asus app for the 3.0.0.6 pro firmware. Asus Expert WiFi
