ASUS RT-AX58U (F/W Ver.:V3.0.0.4.384.8601) with Asuswrt-Merlin 3004.388.5 - Transmission: "Could not connect to the server. You may need to reload"
8helge8
I'm trying to install Transmission on my router but it doesn't work for some reasons with the following error:
Full log of installation Entware and Transmisison:
 Enter amtm option  ep
_____________________________________________
 This installs Entware - the ultimate Software repository
 on this router.
 Visit https://entware.net to learn more about Entware
 Author: thelonelycoder
 https://www.snbforums.com/forums/asuswrt-merlin-addons.60/?prefix_id=16&starter        _id=25480
 Continue? [1=Yes e=Exit] 1
 Running pre-install checks
 Corrected invalid Entware symlink
 Pre-install checks passed
 Select device to install Entware to
 1. /tmp/mnt/Apacer_PHD
 Select device [1-1 e=Exit] 1
 Running device checks on /tmp/mnt/Apacer_PHD
 Device checks passed
 Testing Entware servers availability
    bin.entware.net failed, primary server
 1. entware.diversion.ch - Mirror by thelonelycoder
 2. mirrors.bfsu.edu.cn - Mirror by Beijing Foreign Studies University
 Select Entware server to use [1-2 e=Exit] 1
 amtm is now ready to install
 Entware (armv7sf-k3.2) to
  /tmp/mnt/Apacer_PHD
 1. Install Entware now
 2. Return to device/server selection
 Enter selection [1-2 e=Exit] 1
 Creating install directory at /tmp/mnt/Apacer_PHD/entware
 Installing Entware (armv7sf-k3.2), using external script
Info: Congratulations!
Info: If there are no errors above then Entware was successfully initialized.
Info: Add /opt/bin & /opt/sbin to $PATH variable
Info: Add "/opt/etc/init.d/rc.unslung start" to startup script for Entware servi        ces to start
Info: Found a Bug? Please report at https://github.com/Entware/Entware/issues
admin@RT-AX58U-14D0:/tmp/home/root# opkg install nano
Installing nano (7.2-2a) to root...
Configuring nano.
admin@RT-AX58U-14D0:/tmp/home/root# opkg install transmission-web transmission-d
aemon
Installing transmission-web (4.0.3-4) to root...
Configuring transmission-daemon.
Configuring transmission-web.
admin@RT-AX58U-14D0:/tmp/home/root# opkg install transmission-remote transmission-daemon
Installing transmission-remote (4.0.3-4) to root...
Downloading https://entware.diversion.ch/armv7sf-k3.2/transmission-remote_4.0.3-        4_armv7-3.2.ipk
Package transmission-daemon (4.0.3-4) installed in root is up to date.
Configuring transmission-remote.
admin@RT-AX58U-14D0:/tmp/home/root# opkg install ca-bundle ca-certificates
Installing ca-certificates (20230311-1) to root...
Configuring ca-certificates.
admin@RT-AX58U-14D0:/tmp/home/root# /opt/etc/init.d/S88transmission stop
 Checking transmission-daemon...              alive.
 Shutting down transmission-daemon...              done.
admin@RT-AX58U-14D0:/tmp/home/root# nano -w /jffs/scripts/firewall-start
admin@RT-AX58U-14D0:/tmp/home/root# chmod a+rx /jffs/scripts/firewall-start
admin@RT-AX58U-14D0:/tmp/home/root# /jffs/scripts/firewall-start
admin@RT-AX58U-14D0:/tmp/home/root# /opt/etc/init.d/S88transmission start
 Starting transmission-daemon...              failed.
 Starting transmission-daemon...              already running.
I'm confused - which firmware is your router actually running on?
