Hi.
I just joined this forum because I need some advice about my RT-AX88U router. I purchased it a little while ago to replace my older DLink DIR-632 router. On the DIR-632, I had no trouble accessing my HP 4050TN network printer at static IP address 192.168.1.2 and a PDU at 192.168.1.99, both of which are hardwired via ethernet. However, I can't access either of these devices (using their IP addresses) on the AX88U router.
I tried chatting (for a large part of the morning) with Asus support; but they weren't any help.
Just FYI, the DHCP address range on the AX88U router is 192.168.50.2 to 192.168.50.254, whereas on the DIR-632 it was 192.168.1.100 to 192.168.1.199, although I can't see how this would be relevant, since the static IP addresses are outside the DHCP address ranges.
Is there some setting on the router that solves this problem. The router firmware version is: 3.0.0.4.388-22525-gd35b8fe.
