kevinpurcell
I just got this router today and hooked it up. Speeds whip my Apple AirPort Extreme. However, when I plug a hard drive into the back of the ASUS router and try to copy files to it from my Mac it says it cannot copy the file because there is no more room.
I know that's not true. It's a 4GB WD MyBook hard drive newly formatted. I used to have it formatted Mac OS Extended and then reformatted the drive using a Windows Machine in fat32. So it's nearly empty. I can copy maybe 1 file at a time, but doing more than that returns this error and then I try again and get an error saying the file is in use. I can reboot the mac and copy one at a time.
I've also connected the drive directly to the Mac and it works fine.
I'm running OS X 10.10.3 on a MacBook Pro. I've updated to the latest ASUS firmware and tried reformatting again and resetting the router twice now.
The other issue is a printer. I can see it on the network, but I can't print to it. With both the printer and the hard drive, they show up as connected in the router's status web interface.
