I have a Linksys WRT54G setup as a wireless bridge using Tomato firmware. It's been working fine for months with my AT&T-supplied 2Wire router.
I'm trying to upgrade my network and have set up a new TP-Link TL-WDR3500 N600 router as an access point. It is working fine with all my other endpoints (mostly phones) and now I want it to work with the bridge as well. I have entered the new SSID and security info in Tomato, put everything on a fixed channel etc., but it doesn't work.
Tomato shows the connection with better signal strength than before, but unless I have an ethernet cable hooked up I can't ping the WRT54G. The last time I went through this I had to enable multicast in Tomato (thanks SNB) but now it is enabled and the bridge still doesn't work. Is there some setting on the AP I need to enable to get this to work?
Thanks in advance.
Thanks in advance.
