Sujay Sarma
Hello,
I am purely talking about *wired* LAN performance in my question. Wondering if anyone here have ideas to help before I throw it away in frustration.
Here's the scenario:
I have a 100 Mbps full duplex Ethernet internet connection from my ISP. Previously, speed tests (speedtest.net) have given consistent results in the 94+ Mbps range in both directions. I have a Cisco-LinkSys E900 router as my gateway + LAN router + WiFi Router. WiFi on the router is configured at "G" because I don't have any WiFi devices that can do anything higher than that. On the wired side, I have a PC and more recently a Raspberry Pi 2 connected using Cat 5e cables to ports 1 and 2 of the router. I do a speed test (speedtest.net, statically saved "preferred server" to ensure consistent results) twice a day to confirm I am getting what I am paying for.
ISP connection is a Static IP connection, with lease controllable if you set the router to DHCP IP mode. I tested it both ways, calling the ISP's tech support team to clear DHCP leases and sessions between tests.
The problem:
As of a week ago, I noticed miserable speeds in the range of 20-30 Mbps in my speedtests. Initially, thinking it was an ISP-side issue, I filed tickets. But the technician that came over used his laptop to directly connect (without going through my router) and I realized the router may be the bottleneck. I tested again using my systems (PC and a Laptop) that I was indeed able to get 90+ Mbps when not using the router.
I tried the WMM and QoS settings (enabling, disabling) with no effect. The router had the latest, but stock firmware. I also tried flashing it with DD-WRT firmware and tested again with no improvement in the results.
To workaround the question of if the router is the problem, I tried with two other routers: An old LinkSys WRT54G (that I originally used and upgraded from to the e900) and a new Asus RT N56U purchased off Amazon. Both those routers didn't fare any better and showed the same results.
Any ideas here before I throw away the router? :-(
The problem:
