Client Speed Test Upload over QoS Bandwidth Limit
Seria17hri11er
Hello. I am confused at the moment. After installing Merlin, QoS always seemed to limit a client's bandwidth during a speed test via browser etc. as it was set. I spent time testing and configuring before recently setting up spdMerlin and AutoBW. I could reproduce excellent results at Waveform bufferbloat test, and Cloud Flare's speed test.
Unfortunately after installing a lot of packages using AMTM, every time I test a desktop client [Cat5/6] the upload speeds are over the bandwidth limits resulting in poor bufferbloat/latency.
When I test via WifiMan 5 Ghz WiFi6 80 Mhz on my S21 it definitely seems to control things better.
I did have some of the packages I installed quit working, and I had to completely uninstall, remove data and reinstall to get working again.
I also did the install to add the "CakeQOS-Merlin" tab. Did I bork it doing that?
spdMerlin tests excluded from QoS, but results still look pretty darn good without the horrible latency I am getting when testing via browser at Waveform or Cloud Flare.
CenturyLink VDSL2 Fiber PTM "Quest Legacy"
Phoenix, Arizona, [East Valley]
Wan Packet Overhead: 30
MPU: 0
Mode: PTM
AutoBW
Download
Priority Q: besteffort
Flow Iso: Triple-iso
Nat Lookup: Yes
Upload
Same
Wash: No
Filter Dup Acks: No
Cake Statistics Look good, I think.
Download
Tin 0
Threshold Rate95.57 Mbit/s
Target5 ms
Interval100 ms
Peak Delay38 μs
Average Delay3 μs
Sparse Delay2 μs
Backlog0 B
Packets Sent194
Sent68.39 KiB
Hash Indirect Hits1
Hash Misses56
Hash Collisions0
Drops0
ECN Marked Packets0
Dropped ACK Packets0
Sparse Flows1
Bulk Flows1
Unresponsive Flows0
Max Packet Length1,466
Flow Quantum1,514
Upload
Tin 0
Threshold Rate11.26 Mbit/s
Target5 ms
Interval100 ms
Peak Delay2.31 ms
Average Delay156 μs
Sparse Delay3 μs
Backlog0 B
Packets Sent836
Sent338.82 KiB
Hash Indirect Hits18
Hash Misses706
Hash Collisions2
Drops2
ECN Marked Packets0
Sparse Flows207
Bulk Flows133
Unresponsive Flows0
Max Packet Length1,392
Flow Quantum343
Anyone got an idea of what is going on? Any tips would be greatly appreciated.
Recent speed tests:
With Gratitude
Welcome to the forums @Seria17hri11er.
If your router/network was working as expected before adding additional scripts, does removing them bring back the expected performance?
If so, then don't add those scripts if they deteriorate your network experience.
Will test later. Thanks.
No idea what's going on without router model and ISP plan details.
This is how things are going downhill for most unexperienced users.
Great point! Lots of data points right.
GT-AX6000
ISP plan is for 100 MB down, I don't think they say crap about up.
If you are confused already with your new router - run the stock firmware and get familiar with the features it offers first. It has more than enough features for average home user. If you need something else you don't find in stock Asuswrt - then look at Asuswrt-Merlin extra features. Jumping all in and with USB stick can produce undesirable results and makes your router as reliable as the USB stick.
About your ISP - 100Mbps down is okay, but "I don't think" is not usable piece of information. Perhaps your ISP is 100/10 and this is what you get from it. Online bufferbloat tests are mostly inaccurate and you can run in circles with QoS and scripts forever fixing something you perhaps don't need to fix for normal Internet user experience. Don't apply someone else's settings assuming you have the same issue.
Lol. I am confused about my test results, not my Router settings. lmao. Very aware.
CenturyLink makes no promises on the upload speed my dood. Your not getting my gist there?
As far as the VDSL connection:
Line 1:
61.440/9.727 Mbps
Line 2:
51.197/5.501
Testing, upload rarely sees 14, usually around 13. Never seen good latency results around that upload speed. Needs to be 11 or lower from my testing so far.
That is what I seen only very few posts on, so I am happy to hear you confirm that. Basically sometimes you can get some good results with those test but too many variables right?
Thinking about this, I clearly didn't set up DNSCrypt for great performance and that wasn't helping.
Separate question for anyone.
Cake QoS. May I ask how you might set it up if you were me?
Wife and I work from home. I have a LG Thin Client for work, going into AWS plus a Cisco IP Phone. Wife is on a Dell Optiplex 9010 VPN into work which definitely consumes more bandwidth than my Thin Client. We both take phone calls.
3 Chromecasts on Wifi6 5g
Desktop Gaming PC
2 Cell Phones on Wifi6 5g
1 Chromebook on Wifi6 5g
1 RokuTV on Wifi6 2g
I've read about Cake settings numerous times, but hearing from others is always great.
MPU: 0
Mode: PTM
Download & Upload
Priority Queue: Best Effort
Nat Lookup: Yes
Wash: No
Filter Dup Acks: No
Custom: No
Enable Upload: No
Download:
Dual-dsthost
Upload: Dual-srchost
Quick search shows you can expect 100/10 depending on your distance from the nearest CenturyLink hub.
No scripts, default Asuswrt-Merlin implementation, Manual settings 100 down and 10 up. Test and adjust if needed.
Sweet thanks. I was thinking to go back to it. I appreciate your assistance.
Keep it simple and test one change at a time. If you don't have speed and latency issues with your normal Internet use - there is nothing to fix.
Don't expect everything working the way you think or the way it was advertised.
The more you play with settings the faster you get to common reboot and reset experience.
Desktop Gaming PC
MPU: 0
Mode: PTM
Download & Upload
Nat Lookup: Yes
Wash: No
Filter Dup Acks: No
Custom: No
Enable Upload: No
Download:
Dual-dsthost
The challenge your'e going to have is that if your speeds are not consistent, you either have to set it to the "worst case" and lose those times when you can get better performance, or set it higher and have it not help all the time. Comcast is a good example where they let you burst beyond your advertised speed for a certain number of megabytes then throttles back (mostly for speed test statistics to make them look good in the rankings). If you apply QOS at the advertised rate, you lose that benefit. Or in your case with DSL which fluctuates a lot, same thing.
For 100M download you're probably ok without QOS. 10M upload, depends on how much you're doing in the upstream direction. Video conferencing etc doesn't take as much as you might think Sometimes QOS can do more harm than good. But it is one of those things you'll just have to play with.
Don't be too concerned about bufferbloat scores. That's testing worst case scenario, and if your normal use doesn't match that, then the results are somewhat meaningless. If you regularly upload large files (or do online backups, lots of photos synching to google drive, etc) at the same time someone is video conferencing or using VOIP, then it is worth playing with, that's the main use case for home router QOS in my opinion.
I actually had QOS set up for my Mom's Ooma as when I was remotely fixing her PC and sending files back and forth the phone calls would get choppy (since I have to narrate to her exactly what I'm doing, lol). It may have made a slight difference, but not much. VOIP is very sensitive so the time it takes the QOS to do its thing (TCP has to detect the congestion and throttle back, but keeps trying to ramp up again) it just isn't enough to help much.
Now if you control both ends of the connection, QOS can be extremely powerful and helpful. In these cases where you're trying to control it all from one end, you lose a lot of the benefits.
