I have an ADSL modem/router which I use with PPPoE to connect to my ISP in routing mode.
I want to buy a 802.11n router (I haven’t find any Gigabit switch with 802.11n AccessPoint function) with Gigabit Ethernet ports and if possible with a built-in ADSL2+ modem.
I haven’t find yet such a device so I’m considering to buy an ADSL2+ modem (or maybe keep my current ADSL modem) and to buy a 802.11n router.
That is I’ll have an ADSL modem plus an 802.11n router.
Can you please guide me on how to configure my modem and my router to be able to continue with my current ISP ?
In order to be clear on how I see things, let me explain the solutions i imagine :
1/ Keep my current modem/router in routing mode. Then I’ll have to setup another subnet with my new 802.11n router. This has several drawbacks :
- I’d like to switch the packets in my home network rather than route them throughout 2 routers to join Internet, for performance reasons
- My modem in routing mode will still do the NAT (private/public IP@) but how about the DHCP ? Both of them will do DHCP ?
2/ Put my current Modem/router in bridging mode. Then I’ll have my new router do to DHCP as well as NAT (that is the modem has to just put Ethernet frames on ATM cells without knowing anything about addresses). The drawback is that I’ll lose all my ISP’s supported functions (e.g. I couldn’t have TV services) because my new router is now talking to my ISP not the one delivered by my ISP..
What do you suggest ?
If solutions 1 and 2 both can work, can you tell me how to configure both the modem and the router in each solution, or point me to some papers where people have already done the same configuration ?
Or, if you have a better solution, please tell me about it.
Thanks for your help
nalooti
nalooti
