DHCP relay on RT-AC87U?
Cesc
I am using a RT-AC87U in a Windows domain and I would like to use the domain controller as a DHCP and DNS server.
How can I set the router to relay the DHCP to the domain controller?
You don't need to do anything other than turning off DHCP on the router. Then enable DHCP on your domain controller. That's it.
You only need to use a DHCP relay if your domain controller is on another network.
