Hi all,
I'm no network expert, and am hoping for a bit of advice on my small home netork.
Right now I have mostly Mac and iOS clients on a wifi network, through a Netgear 802.11n router -- I switched to Mac about a year ago, was PC prior to that.
So I also have an old PC wired to the router via ethernet which I use as a home server, and I have two external USB drives attached to that PC. I back up over wifi to one of those drives, and then mirror one drive to the other. I'm generally happy with the setup.
I previously also used that PC/server for other tasks (for example, as a print server, or to run legacy PC software I no longer need) -- but now it's pretty much just a file server.
I'm thinking about getting a new ac wifi router, and I'd like to eliminate the PC from my setup -- and this is where I'm hoping for some advice.
For example, here's one scenario I'm considering:
1) Get ac wifi router with a USB3 port
2) Attach the USB3 port to a USB3 hub, and attach two USB3 drives to that -- I'm also thinking about using portable drives that draw power over USB (so perhaps a powered USB3 hub).
I forget the max reasonable speeds, but I think ac may outperform USB2 -- so I don't mind if USB3 is a modest extra cost -- and I like the idea of portable if I ever want to move the drive (say, from the router to my Mac).
Anyhow, I'd be gratful if anybody can help get me on the right track -- am I thinking in the right direction?
thanks kindly, -Scott
