Just imagine: you'll drop *.torrent-files to Dropbox folder and router download it and report you when finished with a text file placed back to Dropbox folder.
This solution uses Dropbox-Uploader which is already in Entware repo.
1. Prerequisites
asuswrt-merlin firmware on board and a USB drive with Entware installation.
2. Installation
Install necessary packages and fix root account for the cron service:
Place this content to /opt/etc/cron.5mins/torrent-watch.sh
and make it executable:
3. Configure transmission
I'll show only those strings in /opt/etc/transmission/settings.json which need to be changed:
where "download-dir" is a folder on USB drive where torrent content will be placed.
4. Configure Dropbox-Uploader
This part is a tricky one. Proceed here and create new Dropbox application by filling:
Installation is finished. Reboot router and try to place some *.torrent files to the "Applications/Torrents" folder in Dropbox account. They will disappear within five minutes. It means router is "took" them and start downloads. When downloading will be finished, a text file will be appeared in Dropbox folder, named as a finished torrent job. You may take a look inside (a job finish time will be there) and erase it.
You don't need a real IP or open ports to add new torrents. As always, you may point a web browser to <ip of router>:9091 from LAN to see current a torrents activity.
1. Prerequisites
2. Installation
opkg install cron curl dropbox-uploader transmission-web
sed -i 's/root/admin/g' /opt/etc/crontab
#!/opt/bin/bash
if [ -z "$TR_TORRENT_NAME" ]
then
dropbox_uploader list | grep -iE "^ \[F\] .+\.torrent$" | \
sed "s|^ \[F\] ||g" | \
while read item
do
dropbox_uploader download "$item" "/opt/etc/transmission/watchdir/$item"
dropbox_uploader delete "$item"
done
else
echo "Donwload job done at `date`" > "/tmp/$TR_TORRENT_NAME.txt"
dropbox_uploader upload "/tmp/$TR_TORRENT_NAME.txt"
rm -f "/tmp/$TR_TORRENT_NAME.txt"
fi
chmod +x /opt/etc/cron.5mins/torrent-watch.sh
"download-dir": "/tmp/mnt/MYUSBDRIVE/Torrents",
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/opt/etc/cron.5mins/torrent-watch.sh",
- App type: Core,
- App name: <You name it as you wish>,
- Permission type: App folder,
- Push "Create app",
- Name of app folder: Torrents (or any other you like),
- Press "Update".
- App key: value from previous step,
- App secret: from previous step too,
- Access level [a/f]: a,
- …it's ok? [y/n]: y,
- Token request. Please, copy URL from console to web browser and press "Allow" on the web page appeared. Only then return to router and press "Enter".
