eTomm
Hello everyone.
So the two XT8 are connected with ethernet backhaul and the XD6S should instead be connected with WIFI backhaul.
Right now the XT8 are configured in triband smart connect and they work without any problem between them.
The XD6S instead should connect to the 5Ghz-2 backhaul and expose that one to the outside of the house. To force it to connect to that band (that is 160mhz band, and I need that speed outside of the house) I added a Wirlesss MAC filter for the MAC address of the XD6S in the 5Ghz-1 band.
Everything works correctly when I just start the device. But after one hour it gets dissociated and is not able to associate the 5Ghz anymore.
This is the log, the XD6S is the 58** and the MAC ending in 41 is the 2.4ghz, the other in 48 is the 5Ghz.
Due to the strange 1 hour time frame I changed the Group Key Rotation Interval to 1800 but without any difference. I tried even different version of the firmware without any success.
Does someone has any idea of what it can be?
It will be really helpful if someone has some insights.
Aug 24 14:18:44 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Disassociated due to inactivity (4), rssi:-42
Aug 24 14:18:44 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Previous authentication no longer valid (2), rssi:-42
Aug 24 14:18:45 kernel: Flushing net_device wds0.0.1.
Aug 24 14:18:45 wlceventd: wlceventd_proc_event(520): eth4: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 14:18:45 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind 58:11:22:**:**:48, status: 0, reason: Disassociated due to inactivity (4), rssi:-45
Aug 24 14:18:45 wlceventd: wlceventd_proc_event(503): eth6: Deauth_ind 58:11:22:**:**:48, status: 0, reason: Previous authentication no longer valid (2), rssi:-45
Aug 24 14:18:46 wlceventd: wlceventd_proc_event(520): eth6: Disassoc 58:11:22:**:**:48, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 14:19:22 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-48
Aug 24 14:19:23 kernel: Flushing net_device wds0.0.1.
Aug 24 14:19:23 wlceventd: wlceventd_proc_event(520): wds0.0.1: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 14:19:23 wlceventd: wlceventd_proc_event(520): eth4: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 14:19:37 wlceventd: wlceventd_proc_event(539): eth4: Auth 58:11:22:**:**:41, status: Successful (0), rssi:-47
Aug 24 14:19:37 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-47
Aug 24 14:20:05 wlceventd: wlceventd_proc_event(568): eth6: Assoc 58:11:22:**:**:48, status: Successful (0), rssi:-44
Aug 24 14:20:06 kernel: Register interface [wds2.0.1] MAC: 7c:10:c9:**:**:e8
Aug 24 15:15:15 wlceventd: wlceventd_proc_event(520): eth5: Disassoc 7A:55:89:**:**:D4, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:18:12 wlceventd: wlceventd_proc_event(539): wl2.4: Auth 7A:55:89:**:**:D4, status: Successful (0), rssi:0
Aug 24 15:18:12 wlceventd: wlceventd_proc_event(503): wl2.4: Deauth_ind 7A:55:89:**:**:D4, status: 0, reason: Previous authentication no longer valid (2), rssi:-54
Aug 24 15:18:12 wlceventd: wlceventd_proc_event(503): wl2.4: Deauth_ind 7A:55:89:**:**:D4, status: 0, reason: Unspecified reason (1), rssi:0
Aug 24 15:18:12 wlceventd: wlceventd_proc_event(549): wl2.4: ReAssoc 7A:55:89:**:**:D4, status: Successful (0), rssi:-56
Aug 24 15:25:24 wlceventd: wlceventd_proc_event(520): wds0.0.1: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:25:24 kernel: Flushing net_device wds0.0.1.
Aug 24 15:25:24 wlceventd: wlceventd_proc_event(520): eth4: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:25:26 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-46
Aug 24 15:25:30 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Previous authentication no longer valid (2), rssi:-46
Aug 24 15:25:31 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Previous authentication no longer valid (2), rssi:-46
Aug 24 15:25:32 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-46
Aug 24 15:25:36 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Previous authentication no longer valid (2), rssi:-46
Aug 24 15:25:37 wlceventd: wlceventd_proc_event(503): eth4: Deauth_ind 58:11:22:**:**:41, status: 0, reason: Previous authentication no longer valid (2), rssi:-46
Aug 24 15:25:38 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-46
Aug 24 15:25:41 wlceventd: wlceventd_proc_event(520): wds0.0.1: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:25:41 wlceventd: wlceventd_proc_event(520): eth4: Disassoc 58:11:22:**:**:41, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:25:41 kernel: Flushing net_device wds0.0.1.
Aug 24 15:25:41 wlceventd: wlceventd_proc_event(520): eth6: Disassoc 58:11:22:**:**:48, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 24 15:27:51 wlceventd: wlceventd_proc_event(539): eth4: Auth 58:11:22:**:**:41, status: Successful (0), rssi:0
Aug 24 15:27:51 wlceventd: wlceventd_proc_event(568): eth4: Assoc 58:11:22:**:**:41, status: Successful (0), rssi:-46
