Dismiss Notice
Welcome To SNBForums
ipkg: can't resolve symbol '__ctype_b_loc'
Discussion in 'Asuswrt-Merlin' started by mmmmmm, Feb 4, 2013.
  1. mmmmmm
    mmmmmm Occasional Visitor
    Nov 29, 2012
    38
    after installing the following components (on my attempt to install gallery):
    - lighttpd
    - mysql
    - php (with serveral extensions: ctype, mbstring, xml, json, iconv, filter ...)
    it seems they broke my environment.
    When running ipkg list I get the error:
    [email protected]:/tmp/mnt/sda1# ipkg update
    When trying to run transmission daemon I get:
    [email protected]:/tmp/mnt/sda1# /opt/etc/init.d/S95transmission start
    Starting transmission-daemon:.[20:11:09.694] Couldn't read "/opt/etc/transmission-daemon/settings.json": Not a regular file
    [FAILED]
    Can anyone please give some pointers on what went wrong and how to fix these.
    I actually managed to get the lighttpd and php running. Also the mySql was ok.
    Thank you
  2. mmmmmm
    Nov 29, 2012
    38
    I realize that this is Linux related (not Asus, RT-N66U or Merlin's version), but can anyone please provide some assistance?
    Is it possible that a firmware rewrite/upgrade will solve this?
  3. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    19,363
    Canada
    The problem seem to be with your Optware/Entware repo. I'm not really an expert at fixing package conflicts, best I could suggest is to rename your current asusware directory (or whatever directory contains your Entware filesystem), reboot, and restart from scratch. You can copy back any customized file from the backup you made before rebooting.
  4. mmmmmm
    Nov 29, 2012
    38
    You are absolutely right.
    I realized that I combined packages from optware & entware.
    I simply removed the asusware directory and reinstalled everything from scratch, but this time only entware packages. Now everything is ok.
    Thank you very much, RMerlin!
  5. mmmmmm
    Nov 29, 2012
    38
    To whom it might interest:
    The firmware upgrade did not solve the issue (I lost jffs contents in the upggrade process :) )
    The problem was, as Merlin stated, mixing Optware/Entware repositories.
    The solution was a clean reinstall only from Entware.
Share This Page
