LT2P/IPSec (IKEv2) Server - Recommend a router?
davejuk
I require an always-on VPN connection from my iPhone 6S (iOS 9.3.2) to my LAN.
iOS only supports always-on VPN using IKEv2 (the iPhone must be supervised through Apple Configurator). I cannot use OpenVPN because it would allow the client to disconnect and connect directly to the internet.
So I am left looking for a router with a LT2P/IPSec (IKEv2) VPN server.
Can you recommend a router?
Hi, any router from ASUS models 68u or higher will do the job perfectly.
Their VPN server works great and you can have it work with your iOS without any issues.
Thanks for the reply.
You're sure it uses IKEv2 so I can connect through iOS for always-on VPN without using an app?
Again, it MUST be LT2P/IPSec (IKEv2) - I cannot use OpenVPN because it is an app, not an always-on VPN. Please refer to my original post.
If I could use OpenVPN then I could use any old router with a VPN server.
