Hi there,
I am looking for a new Router which I am only going to use as a WIFI Access Point.
Currently I am using an Apple Airport Extreme 5th gen which is breaking down slowly (2,4 GHz Radio went dark, 5GHz Radio has outages for a few weeks).
The new Access Point will be connected via GBit to my ISPs Router (which has shirtty WiFi) and provide the WiFi.
I have these clients using WiFi:
2 iPhone 5s
2 iPads (4th gen and soon the new Air thing)
1 Android Smartphone
1 Desktop PC (wireless n)
The rest (including the plex server) is wired.
These are my priorities in a new router in order of importance:
1. Configurable as an Access Point.
2. working flawlessly with that Apple stuff (Airplay, Airprint and so on)
3. Stability (this was the reason, I got that overpriced Airport Extreme in the first place and I have to admit: It delivered until recently)
4. Coverage
5. Speed (two, better three Full HD streams should be possible)
Both 2.4 GHz and 5 GHz networks should provide good coverage, both vertically and horizontally. My Extreme is at its limit here. It just barely provides enough coverage.
I have no intention of tinkering in the new APs settings much. I would like "set and forget" but I don't mind setting it up and doing Firmware Updates from time to time. What I absolutely don't want is a WiFi connection which drops from time to time for no good reason.
The iOS devices are used for streaming from my local Plex server. This is the main reason I want speed. I don't think this will be a big issue since my Extreme provided that just fine (at least with two Full HD streams).
Also I would like to be able to surf the internet on my lawn, so it doesn't need to be very speedy at far distances. This is where I need improvement over my Extreme.
At this point there are no "ac" devices here but you never know and I basically use these things until they break down or get too slow (which only happened to my trusty DIR 635).
What i don't need:
- NAS Performance
- fancy QoS stuff (my ISPs Router provides that)
- VPN functionalty
From the reviews here I picked out these four candidates (but I am open to suggestions):
- Netgear Nighthawk X4 (188€)
- ASUS RT-AC87U (206€)
- Netgear Nighthawk R7000 (159€)
- ASUS RT-AC68U (169€)
I read all the reviews on snb but they are at least two months old. Since the new routers basically ship as beta gear I thought maybe two months later they smoothed out the quirks. I am guessing all four are configurable as an AP?
So the question is: Which one should I get?
thanks a lot!
2 iPhone 5s
4. Coverage
What i don't need:
- NAS Performance
- VPN functionalty
thanks a lot!
